Old 08-29-2016, 04:52 PM   #1
JDM Jim
JDM Jim is an unknown quantity at this point
Push Button Question
Hi guys, I couldn't find a forum for things involving the electrical part of cars so I figured to come here. To start off I wanted to know if there is a place online that makes push buttons that are square, rubber coated and you could push more than once for a high/ low setting? I like the look of the buttons on a CAN keypad and I wanted to see if there are buttons like that in which I could just wire say lights to. I will try to insert a pic of the button things I am talking about. Thanks Also if you can figure out what I am looking for because I am not good at explaining things can anyone tell me how one would hook up a key pad like the one in the pic? The reason I want individual pads are so I dont have to use a software to use it and its probably cheaper. Thanks
JDM Jim is offline   Reply With Quote
Old 08-29-2016, 05:05 PM   #2
justinbyrant
justinbyrant is an unknown quantity at this point
not exactly what your looking for but this thing is fucking sweet
http://www.altronicsinc.com/switch-p...erquest-1.html
I don't know of anyone that makes switch panels with multi use buttons, usually I see them with a low on one switch and high on another switch
justinbyrant is offline   Reply With Quote
Old 08-29-2016, 05:09 PM   #3
JDM Jim
Thats cool i like the touch pad, but I am trying to find like rubber buttons that you can wire up because in those keypads like the one pictured you have to have some wiered connector that goes to the ecu or some soft ware thing but they are like $700 so I want to find individual pads i can wire anything too. IDK if that makes sense hahaha
Old 08-29-2016, 05:16 PM   #4
justinbyrant
no the one I posted is a totally stand alone self contained unit, you can run only fans, and amp turn on and other completely unrelated stuff if you want, you just wire everything to the control box then its a usb plug up to the touch screen
Old 08-29-2016, 05:25 PM   #5
JDM Jim
ohhhh ok thats pretty cool. Wish it wasnt so expensive though probably good quality though so it's probably worth it
Old 08-29-2016, 05:43 PM   #6
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Motec makes exactly what you want.
http://www.motec.com/aboutpowerdistr...utionoverview/
[email protected]
hanzbrady is offline   Reply With Quote
Old 08-29-2016, 06:06 PM   #7
JDM Jim
Originally Posted by hanzbrady View Post
yeah but im trying to find just those little buttons that i dont have to put through a pdm. I could just wire a fan right to it.
Old 08-29-2016, 06:06 PM   #8
JDM Jim
to be honest i dont even know if they make those little rubber push pads separate I can not find them anywhere
Old 08-29-2016, 06:09 PM   #9
hanzbrady
hanzbrady's Avatar
Well the Motec stuff only works as one modular system, as for a stand alone unit that is somewhat like that you could look into the ARC system, it's what I have in my car
https://www.google.com/url?sa=i&rct=...72602100694934
[email protected]
Old 08-29-2016, 07:21 PM   #10
JDM Jim
do you happen to have any in car pics?
Old 08-29-2016, 07:24 PM   #11
hanzbrady
hanzbrady's Avatar
Apparently only one very bad one during mock-up haha, the car is still being built.
[email protected]
Old 08-29-2016, 07:25 PM   #12
JDM Jim
cool stuff do you have any complaints with it? and was the ribbon wire an excessive amount? I can see some back there?
Old 08-29-2016, 07:28 PM   #13
hanzbrady
hanzbrady's Avatar
No it's great, and it comes with it's own wired compact relay/fuse block. It's as simple as add power and wire outputs, also all of the switches can be configured from constant to momentary. As for the ribbon cable it is long but it's a race engineered part that was designed with rollcage mounting in mind so it has enough cable to comfortably run to the top of the windshield if I wanted. The excess will be easily ziptied.
[email protected]
Old 08-29-2016, 07:30 PM   #14
JDM Jim
good stuff thanks for the help!
wiring problem
