Injectors not firing
I have Mazworx SR22DET using a Haltech Platinum Sport 1000 and the tuner can not get the injectors to fire. I have googled this problem and others have had the same issue but no one seems to post what the solution was. The injectors are ID2000's and the motor ran with this set up on a Haltech E8. Once the Sport 1000 was hooked up the injectors won't fire. Wondering if anyone has ran into this issue and what they did to fix it. I am pretty sure it is a programming issue.
BTW, all of the common issues have looked into like TPS Calibration and CAS.
Sr22 in the works
