Old 11-02-2016, 03:00 PM   #1
bmar19
bmar19 is an unknown quantity at this point
Blacktop SR20det help needed
Hey guys. I have been having some issues with my SR lately. I will try to describe everything as clear as possible so I can maybe get a little insight that I'm overlooking at the moment. I have pics and video and you can see kinda what im talking about..and also hear the misfire…
I have a 95 S14 with a S13 blacktop E5 ecu I will list all mods below then go into the issues I'm dealing with as well as everything I have done, tested and tried.
Mods:
S13 blacktop
garrett gt2871r turbo
fmic
wiring specialties pro harness
RS enthalpy tuned ECU
Flex a lite fans for s14 (on all the time)
alternator rebuilt
new battery optima
fuel pump is rewired with a relay and getting 14volts
walbro 255
battery in the rear
denso 550cc injectors
aeremotive FPR
z32 fuel filter
NO BOV
isr intake manifold
new ngk bkr7e .032..used to be at .028 same thing
Ok so issues
when I first start the car it idles up normal for about 10 seconds then rpms drop and sometimes will die and sometimes stumbles bad for a few than can pick up normal then die ... when i start it again its all good no problem.. suspect IACV but cleaned it all out and set idle with TPS unplugged .. It will also almost die when I come to a stop the rpm dip low sometimes bounce around up and down and evens out randomly will die (No bov)
when warm idling
the car will sometimes idle lean according to my afr gauge AEM and the sensor is good and tested... you can hear a slight misfire at idle and the gauge is lean showing 17s to ---
also at times at idle the afr will go to 10.0 and stay there for a few min then something changes and shoots back to lean..you hear the motor miss a beat (misfire i guess) go lean and dies..
if its idling at 10 and i turn ac on it goes lean...turn ac off and it goes rich...also sometimes when ac turns on the rpm don't rise and the car dies...
also at idle...if i turn wiper on the volts drop in the car when the wiper moves and almost kills the car and lets say I hold the rpms around 3k and the wipers move the rpms drop....checked this will a multi meter not sure if this is normal
even just at idle sometimes the car will be steady and randomly the volts drop and car will either die or stumble...
driving...10lbs car will be lean in boost around 13s sometimes high 12s
cruising I'm at 14.5 to 15.1 so normal
my eyes also burn at times when driving…not sure if its just my contacts or what but they do bother me when im driving my car
What I have done/checked:
MAF - 1.05volts at idle. cleaned and tried another no change..its grounded to chase as well
Coils - ohm checked all good, grounded to VC bolt
ignitor - checked and passed
injectors - ohm tested
fuel pump new and rewired with relay
ECU check by martin at enthalpy and all good
engine compression good
no boost leaks
no vac leak (smoke tested)
TPS checked.. .44V and smooth up to 4.7v
timing is correct even tho it does bounce around when checking with a timing light but it was set right
in the pics you can see my grounds i have...i have one off the head to chassis, one off the intake to chassis, one off the alt to chassis, the oem one on the back of head to the bracket, and a ground from tranny to chassis firewall
bmar19 is offline   Reply With Quote
Old 11-02-2016, 03:19 PM   #2
bmar19
finally got video embedded and pics up sorry i know its a bunch of random info but its what I'm dealing with which is very frustrating..
Old 11-03-2016, 07:55 AM   #3
jedi03
eyes burning could be exhaust leak, I adjusted my iacv to help with the dying...the afrs could be tune if pump, fpr and injectors are good, oh and also if fuel filter is good still too
Old 11-03-2016, 10:29 AM   #4
bmar19
yeah i did find exhaust leak so i will be fixing that with a new mani to turbo gasket...
we checked the tune and it was good fuel pump and filter are new i also use the poem sock not the little one that comes with walbro... not sure if you saw the video but its a definite misfire with the rpm up around 3k and also they drop when i turn the wipers on even if I'm holding the pedal down..i was thinking a ground issue but idk all my grounds seem good
Old 11-06-2016, 06:18 PM   #5
Kingtal0n
Kingtal0n's Avatar
for starters, disconnect any O2 sensor narrowband you have. Then see how the wideband responds.
Second. I dont see anything about cams. Stock cam? If so go to third
third, the wideband reading at first, looks bad/wrong. like you have an exhaust leak somewhere nearby. If not, then I would suspect a boost leak. You should have pressure tested the system with 15~psi first. If you did this, go to fourth
fourth, O2 narrowband still disconnected, no exhaust leaks, pressure test done, I suspect either bad maf (try cleaning it) or poor ECU config (tune related) or an injector leak.
The misfire symptom is because the fuel is going all over the place. The fuel is going all over the place because something in the chain of command (maf -> ecu -> injector) isn't right.
tinyurl.com/4l80er
Old 11-06-2016, 06:27 PM   #6
bmar19
Thanks kingtalon I did find exhaust leak between manifold and turbo, also leak at the turbo to elbow gasket. Getting that fixed soon. So I'll check everything again once that is done. I do need to get injectors checked just to be sure. I have not removed them to check 100%... Maf has been cleaned and tried another no change. No boost leaks
I'll try narrow band again. I did it once. Never really noticed a change. The biggest thing I'm worried about is the electric draw I guess it is when I hold the recs up and the wiper goes it makes the revs drop even if I'm holding the pedal constant at 3500 rpm
Once I fix the exhaust leak I'll check back in. You came to my house once with your white kouki. To pick up a PS pump. Love that kouki haha
Sent from my LGMS631 using Tapatalk
Old 11-06-2016, 06:46 PM   #7
Kingtal0n
Kingtal0n's Avatar
Hey whats up.
If you suspect electrical draw/issue there are a few major wires to check. The first is battery (-) goes to both the intake manifold and chassis (by the battery tray). There is also a very important ground from the coilpacks to the back of the head. check these first.
Next the 12V off the battery, it should go to starter and alternator with low resistance (large cable). You can check the resistance (do a continuity test) with a multi meter if you have any doubts about any of these major wires.
From there, the harness is suspect. If you are using a wiring specialties harness there is a chance the problem is inside that. I have found sometimes their harness does not make a good connection somewhere, for example I found a poor coilpack connection at the ECU plug which would intermittently mis-fire on an engine. I had to shove some small bits of wire into the ECU plug to make it connect well enough to keep the car going.
tinyurl.com/4l80er
Old 11-06-2016, 06:57 PM   #8
bmar19
Yeah I have wiring specialties.
Battery is in the trunk. The (-) is ground to chassis. Paint removed and less than 2ft. It's 1/0 gauge battery cable for both positive and negative. Positive goes directly to the starter, with ecu power and alternator cable as well.
All my grounds checked out including the ground for coil packs. I have a ground off the intake to chassis, head to chassis ect as in the pics I posted.
All these issues were not present before even with the harness from wiring specialties. And it's not like it just started with anything changed. It's just out of nowhere kinda arrived and the dying is fairly new. Before it was just a lean idle and lean in boost intermittently
