Old 11-13-2016, 01:46 AM   #1
toby763
toby763 is an unknown quantity at this point
Needing Advice
Alright, guys and gals, here's my issue.
I recently bought a '92 240 with a redtop swap. First problem was that the fuel pump wouldn't prime at any time unless I hardwired it. Car has an APEXI FC ECU, and I wasn't sure if that was the issue, seeing as I checked the grounds, relays, ignition, and replaced the fuel pump and filter. No luck. So I started pulling wires, looking for any possibility of any ground or split wire. Couldn't find one. Decided to splice main ignition power with the fuel pump power wire to get power whenever the ignition was in the "ON" position. Now, even after the splice is removed and the fuel pump is hard wired to run, the car will turn over, run on it's own for 1-2 seconds, then die. Then it won't start at all for a few minutes after that. I've already ordered a new wiring harness. My question is whether or not I should swap to a stock SR20DET ECU just to get it to run until I get home or try to troubleshoot until I figure it out.
I'm asking because I'm in the Navy, stationed in Hawaii, and I'm about to move back to the states when I get out next year. I don't exactly have a lot of free time, and I'm wondering which option, if any, is the faster one. I'm desperate for help, guys. Anything would be appreciated. I have large plans for it when I get into a job that allows me weekends and time off to work on this thing
-Toby
toby763 is offline   Reply With Quote
Old 11-13-2016, 09:18 AM   #2
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Should have posted in small questions thread or technical section. Youre gonna get flamed
Skurr Skurr
DJTTon is offline   Reply With Quote
Old 11-13-2016, 09:24 AM   #3
JM216S14
JM216S14's Avatar
JM216S14 is on a distinguished road
Best advice I can give you is sell the car, and don't return to the main land.. Hawaii is way better..
JM216S14 is offline   Reply With Quote
Old 11-13-2016, 12:06 PM   #4
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
Swap the ECU, the ECU could be bad.
Frank_Jaeger is offline   Reply With Quote
Old 11-13-2016, 01:53 PM   #5
tuzzio
tuzzio's Avatar
best advice on zilvia. beat me to it
Old 11-13-2016, 04:52 PM   #6
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Best advice would have been not to buy it. Now your best advice is sell it.
SupaDoopa is offline   Reply With Quote
Old 11-13-2016, 06:09 PM   #7
Malik
Malik's Avatar
Malik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant futureMalik has a brilliant future
small questions thread is your best bet. no one in general chat really cares
Malik is offline   Reply With Quote
240sx, ecu, electrical, sr20, wiring
