Old 12-08-2016, 09:33 PM   #1
Tjk2world
Tjk2world is an unknown quantity at this point
s13 How me design my drift tire setup! (I have odd wheel sizes)
I drive a KA-T and I want to start drifting.
I have four 17x7.5 (grey ones) sport comp wheels running tires:
215/45's
I have two 17x9.75 (black ones) xxr wheels running
255/40's
I have no idea whatthe offsets are but i have pictures included to try and give you guys an idea.
My plan is to daily the car and drift it here and there. I'm assuming i would run the wide rims in front and the skinny ones in back. Since i would have 4 skinny ones i could swap them out when i burn them.
Is this tire setup ideal? Should i change the tires (i have to stick to the wheels i have)?
Is there a more common tire I could use on the wide ones? Everywhere I talk to says the are a very uncommon size.
Should i change to 255/45 to match the back? 245/45? 245/40? Im lost when it comes to tire science. Thanks in advance.
Yes I searched, but i need someone to help me work with what i have.
Pictures: http://imgur.com/a/C75rU
Tjk2world is offline   Reply With Quote
Old 12-09-2016, 12:20 AM   #2
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Just burn up cheap tires thatll fit on the rims for now youll figure out the rest as you go
I know it isnt the answer you wanted, but its the answer you clearly need
zombiewolf513 is offline   Reply With Quote
Old 12-09-2016, 08:07 AM   #3
gaz_moose
gaz_moose is an unknown quantity at this point
I would daily with a pair of 7.5's on the front and the 9.75's on the back and drift on the other pair of 7.5's just to give you better grip on the road
basically you want to drift with equal tyres all round or wider on the rear
having wider on the front and skinny rubbish tyres on the rear will give a poor handling car.you will just spin out a lot.
or do as you say drift on the 9.75's
I use 215 40's up front on a 9" rim and 225 45 on the back with 9 or 9.5" rims
If I was you I would look to getting some nicer wider front rims and use all your FWD spec 7.5's as drift rims.
gaz_moose is offline   Reply With Quote
Old 12-09-2016, 08:45 AM   #4
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
Tire science is a tricky topic. You need to determine the desired slip angle at all times during a drift to choose your tire size. First take the width of your wheels and convert to mm. Subtract 25% of the width and that will give your tire size. Your aspect ratio is found by calling each manufacturer and asking for the corning stiffness of each compound to control how much your car oversteers or understeers.
Good luck!
bmaddock is offline   Reply With Quote
Old 12-09-2016, 08:48 AM   #5
bmaddock
bmaddock's Avatar
..kidding. What zombiewolf said, don't think about it too much and drift on what you got. For your first event just play with tire pressures if anything.
drift, s13, tires
