Old 10-06-2004, 11:18 PM   #1
ass15
ass15's Avatar
ass15 is an unknown quantity at this point
How to Remove/Install (s14) Wheel studs
my nismo 60mm should arrive soon. guys can you direct me to site or help me on how to remove/install wheel studs..
how hard is it? by the way
thx in advance..
ass15 is offline   Reply With Quote
Old 10-06-2004, 11:22 PM   #2
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
screw the nuts out to the very end, get a big hammer, and whack. put the new studs in, screw the bolt on until they set themself
wootwoot is offline   Reply With Quote
Old 10-07-2004, 05:13 AM   #3
Raine
Raine's Avatar
Raine is an unknown quantity at this point
Send a message via AIM to Raine
Basically you puond them out mad silly. First raise the car on jack stands, remove the wheels, and remove the entire brake caliper assembly (you have to remove the brake disc, that's why). Then get a huge hammer and pound away on each stud until it falls out of the back of the hub. Once all the old studs are out, put the new ones in through the back and use an open-ended lugnut to tighten them into place until the studs are seated flush with the back of the hub. Make sure before you start tightening the nut that the small teeth on the new studs match up with the teeth on the hub.
Done.
- Raine
Raine is offline   Reply With Quote
Old 10-07-2004, 06:08 AM   #4
PSI240SX
PSI240SX is an unknown quantity at this point
Be careful which lugnuts you use when doing this.... I had big factory ones, and when I tightened them down the correct way, the side of the nut facing the rotor mushroomed out from the force smasing it into the rotor and they would not come off. I had to turn them around backwards so the flat side of the nut was facing the rotor to avoid this.
www.enjukuracing.com
PSI240SX is offline   Reply With Quote
Old 10-07-2004, 09:43 AM   #5
projectRDM
projectRDM's Avatar
There is no need to remove the caliper or rotor unless you enjoy wasting time.
Take the wheel off, use a good hammer and pop the old studs out, one good hit is all it takes. Then reach in from behind and seat the new one, use an open-ended lug nut or a close nut a stack of washers to pull it through, then put the wheel on and properly torque it.
FORMERLY R240NA
Old 10-07-2004, 12:08 PM   #6
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
I used to do it by stacking washers or what have you then tightening a lug nut down to pull it through until last week. I did this, and just before it was pulled all the way through, the stud started spinning in the hole. so now i can't get it out, can't put my wheel back on, i'm screwed. had to take the whole hub off the car and get it ground off and had a new one put in. after the guy cut it out with a grinder, he HAMMERED the new one in. this way the stud isn't inclined to spin and round off the splines. If I ever have to replace a stud again, i'm going to take the time to take the hub off and hammer the new one in. just a heads up, I thought it was gonna take 20mins, and my car ended up being undriveable for 2 days.
r240na: how are you gonna reach around to put the new one in, or take the old one out for that matter, if the brake rotor is covering all of it up? I'm not sure what you were smoking when you did this........ but it sounds like some pretty good stuff.
RBS14 is offline   Reply With Quote
Old 10-07-2004, 12:22 PM   #7
projectRDM
projectRDM's Avatar
The rotor doesn't cover up the back of the hub, it covers the front. Smoking has nothing to do with it, I've replaced three or four on my own car just like I described, as well as a few others. Have you ever looked behind the hub? It's an open area, there's nothing blocking the back of it. The stud will fall right out after it's hit, the new one will go right back in. The last one I replaced I never even took the wheel off.
*edit* After rereading, I'd like to note that this method works for cars more easily without backing plates, as they're not in the way. I don't replace studs on a car very often that doesn't have Z32 brakes already fitted, so it definitely makes it easier, but you can still access the back of the hub somewhat with the backing plate installed.
FORMERLY R240NA
Old 10-07-2004, 01:42 PM   #8
ass15
ass15's Avatar
..i was always concerned about hameering the old studs to get it out.. i mean won't that damage the thread design on the old studs and thread wall on the hub?
thx
Old 10-07-2004, 02:53 PM   #9
projectRDM
projectRDM's Avatar
thx
If you can't aim for shit, yes.
One direct blow to the end of the stud with minimal effort will knock it right out.
FORMERLY R240NA
Old 10-07-2004, 03:08 PM   #10
MakotoS13
MakotoS13's Avatar
MakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-knownMakotoS13 is making his/her stupidity well-known
Send a message via AIM to MakotoS13
, and just before it was pulled all the way through, the stud started spinning in the hole... ... i'm screwed.
same exact thing happened to me only i had a whole wheel on and the caliper off. talk about a bad day.
and this is the reason i'm buing attain hubs when i go 5lug
MakotoS13 is offline   Reply With Quote
Old 10-07-2004, 06:48 PM   #11
96twofourty
96twofourty is an unknown quantity at this point
do it right, use a press
96twofourty is offline   Reply With Quote
Old 10-07-2004, 07:01 PM   #12
RBS14
RBS14's Avatar
makoto: attin hubs aren't immune, i've got a friend who had it happen to his........
Old 10-07-2004, 07:04 PM   #13
MakotoS13
MakotoS13's Avatar
they are, however, brand new as opposed to the questionable junkyard stuff we usually snag.
