Old 01-18-2017, 12:56 PM   #1
ZLady
ZLady is an unknown quantity at this point
1990 300zx drift ready
Selling my drift ready 1990 300zx. $6,500 OBO! Worst I can say is no.
This car was great to me this last year but looking for something else for me for next year. I drove this car to every event 2-3 hours away drifted it and drove it home, never failed me as I did about 10-13 events!
Car has a swapped 94 vg30de engine and a 94 trans with around 75k on them. Body has almost 200k. Custom made roll cage put in when it was pro am drifted. The underbody is very solid!
All listed below has less than 6k miles on them
Dual pop chargers
Inland one piece drive shaft
Lightweight flywheel and pulleys
New radiator
New belts
New plugs
New valve cover gaskets
New lower intake manifold gasket
New upper intake manifold gasket
New rear main seal
new headers that are header wrapped
Dual intake fuel filter relocation
Fuel dampener delete
Nismo fuel pressure regulator
Z1 twin disc racing clutch
Upgraded 350z clutch fork chromoly pivot ball
New trans output shaft seal
TYC dual electric fans
New injector pigtails
New coil pack pigtails
Every connector on engine harness has been replaced
Socketed and chipped ecu done by SZ runs on 93 octane
New pro sport oil pressure water temp and volts gauge
Walbro 255 fuel pump
Kts coilovers and spl suspension parts, new tie rod ends
Inline hydro brake
S14 welded diff
Top speed short throw shifter
Z speed solid shifter mount
Z1 solid aluminum engine and tranny mounts
Oem timing kit
Full deletes
BDE bronze shifter bushings
SS 1 piece clutch line
All new silicone hoses and fuel lines
Custom 2.5" exhaust to single n1 muffler
Car will also come with a box of extra stuff and I have a great conditioned stock z32 TT wheels (which are worth more than NA wheels)
Also have modded shortened knuckles made by Bryan that aren't installed but can throw them in with the sale.
Just about everything on this car was replaced when swapped with a VG back into it. Obviously body isn't perfect but it's been on the track for about 10 years.
Prefer cash/bank check or I will consider trade for another rwd car or a decent truck, would have a little cash to add on top if needed.
Car was built by a very reputable z32 owner. Feel free to ask any questions also have a lot more pictures if you're a serious buyer.
Thanks for looking.
My number is 715-210-9144
My name is Jayleen
If you have any other questions or want more pictures.
ZLady is offline   Reply With Quote
Old 01-18-2017, 12:57 PM   #2
ZLady
Not sure why the pictures split up the text! Sorry about that!
