Old 10-09-2004, 01:40 PM   #1
nd240sx3
nd240sx3's Avatar
nd240sx3 is a well-known jackass
Send a message via AIM to nd240sx3
i know old thread but can get a definitive answer
god damn charcoal canister, i know the two top hoses get plugged but the bottom that goes to gas tank do i let it vent or plug it, and if u might ask why remove it well everyhting is goin or already gone for ka-t swap i want nuthin in the engine bay i definitly dont need so it must go, along with ac,ps and egr which all i did was put block plate on will that be ok thanx
nd240sx3 is offline   Reply With Quote
Old 10-09-2004, 03:04 PM   #2
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
ok what I did, is remove the whole hard line, It ends at around the firewall, If you want to explore removing the second hard line, do so, i dont know much bout it but I removed the front hard line and kept the rubber hose, ill prolly mount it so it vents to the back, i donno if its bad to let it vent there, I just wont smoke under my car is all.
I was going to, but I can not think of a sig less than 75 characters.
mjjstang is offline   Reply With Quote
Old 10-09-2004, 04:04 PM   #3
nd240sx3
nd240sx3's Avatar
i figured it out
i ran it to that elbow tha goes into the frame rail under charcoal can. the big line under canister well i cut metal line alil short and ran it to the elbo so the fumes go into the frame rail but thanx hope this helps out
Old 10-09-2004, 05:51 PM   #4
projectRDM
projectRDM's Avatar
You're both right, make sure it's vented.
FORMERLY R240NA
Old 10-09-2004, 06:33 PM   #5
Phlip
Yes, I look like that
Phlip's Avatar
Coming from the man who DEMANDS that everyone he meets that still HAS that canister remove it no sooner than immediately, giving concise directions... I'm almost scared to show you the new car dude
Weirdo
And I write too!
