![]() Hey guys, I'm having trouble getting my transmission to align in my s13. The crossmember and the motor mounts are all lined up corrwcrly. But it just won't wont line up to the shifter hole. What am I doing wrong? Could the bushing on the crossmember be bad? It wants to sit really far off to the passenger side.
Any help would be amazing! This is driving me crazy. |
#2 | |
![]() Join Date: Feb 2012
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Picturessssss Sent from my iPhone using Tapatalk |
Sorry I was on my phone and couldn't upload a photo.
Here's the issue I'm having. When everything is hooked up, the back of the transmission wants to pull to the passenger side. I can grab it and pull back to the drivers side, but then it goes back to the passenger side. All of the mounts are lined up correctly so I don't understand what the issue would be. Is it just a bad crossmember bushing? |
#4 | |
Trader Rating: (31)
Dude if your trans is bolted to the engine and you can really swing it as much as you're saying, you need to look at motor mounts too. Get a cherry picker to hold the Motor, loosen all three mounts, and wiggle it with the motor slightly pulled from the chassis. Something did not sit right or you have isolating motor mounts(separate studs to not transfer the vibration) that were not installed symmetrically (ie: the offset post is on the top and one is on bottom) Sent from my iPhone using Tapatalk |
#5 | |
#6 | |
Trader Rating: (31)
Oem as in original? If so you need to get new mounts. All three. Sent from my iPhone using Tapatalk |
#8 | |
did you put the motor mounts on the correct sides? there is a right and left side mount and should be marked. will go in on wrong sides.
is this a case of auto to manual trans swap? the trans crossmember brackets are different as well between auto and manual
#9 | |
And yes, it's an auto to manual swap. There was a crossmember on the trans when I bought it. And a friend gave me another one. I have the same issue with both crossmembers. |
#10 | |
u have to unbolt motormounts from the brackets to see what it what. one should have an r or L on it letter usually on backside facing block iirc
hard to tell from this pic but they are different. ![]()
#11 |
Hmm. My mounts might be messed up then. The description of the mounts said they would fit either side okay. And everything matches up okay. But I guess they could be wrong.
#12 | |
theres only 4 reasons you can be off. motormounts are wrong, brackets are wrong, you are doing something wrong, or chassis is fucked.
edit: looks like they do make ones that fit either side now (via autozone site)... my nismo mounts had a right and left side. the oem ones shown above have right and left side
#13 |
haha probably all of the above honestly. If worst comes to worst I'll have a new crossmember fabricated that pulls it into the correct place or something.
#14 |
Here are a few pictures of my motor mounts, plus the crossmember on my trans and a few extra ones I have. I believe one of my extra crossmembers came off the auto trans I pulled from my car.
Is it possible that I'm just stupid and have the crossmember on backwards? |
#15 |
![]() Join Date: Nov 2012
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 7 reviews
make sure the nipples on the mount are aligned in the correct positions on the engine brackets and the front cross member. mount should be good for either side like ppl have said. either your car is jacked and bent or you did something wrong.
has the front cross member ever been removed? are youre engine mount brackets straight? I cant remember if you can mount the trans mount backwards or not |
#16 | |
My dad and I have narrowed it down to either the one-piece driveshaft is too long, or the front end is actually messed up. |
ka24, s13, transmission |
