Old 02-27-2017, 05:22 PM   #1
silvia910
silvia910 is an unknown quantity at this point
ECU plug doesnt even have consult wires pinned
I went to try to hook up my consult cable to my car and realized it wasnt working. After taking a look at my ecu plug, I realized that there arent even any wires pinned into 7, 14, 15, or 23. Why would there be an instance where that wasnt even present?
It's a 92 with a redtop SR, 63 ecu
How should I go about hooking up my consult port? I cut the consult port off from the drivers side to go and splice it into the ecu when I realized there werent even any wires pinned into those slots. I went everywhere in town looking for a place that sold those pins so I can just put pins onto my consult port wires and pin them in myself; but apparently I cant find anywhere that sells the pins. Any suggestions?
silvia910 is offline   Reply With Quote
Old 02-27-2017, 06:34 PM   #2
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
do you have a old harness lying around? If so, just unpin some random wires and and plug them into the sr harness connector. And then splice the consult connector wires in to those
Javi802 is offline   Reply With Quote
Old 02-27-2017, 06:46 PM   #3
silvia910
I don't. And I'm trying to find a better solution that having to go to a pick and pull just to grab a spare ecu connector
Old 02-27-2017, 08:29 PM   #4
EnnEssEnnKAT
EnnEssEnnKAT's Avatar
EnnEssEnnKAT can only hope to improve
Interesting..that would really suck to find as you go to get things running. Bet it was removed if those are the right pins.
Sent from mTalk
EnnEssEnnKAT is offline   Reply With Quote
Old 03-10-2017, 09:25 PM   #5
silvia910
Went to the pick n pull and had no luck in finding any spare ecu harnesses or connectors. Grabbed a bunch of random connectors, hoping it I can just depin one and use those pins but none of them came out or were right. Any other suggestions?
Old 03-11-2017, 03:59 PM   #6
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Would this help?
http://www.wiringspecialties.com/2pinconnector.html
Plus some Nissan ECU pins large and small.
http://www.wiringspecialties.com/nissan-ecu-pin-kit/
blkvrtswp is offline   Reply With Quote
