03-20-2017, 10:54 PM | #1 |
97-98 240SX LED low beam bulbs
Hi all. Tried searching but couldn't really find anything useful.
I'm thinking of buying one of those LED (not HID) conversion kits for the factory low beam projectors (1997 or 1998 cars). I was wondering if anyone has done it. Anything you can mention or suggest about installing them, how well they fit, do they require any modifications or not, and how good they actually work on ours cars, that would be great. Thanks. something like this (not this specific kit): https://www.amazon.com/Headlight-Con.../dp/B01FI1DOMG |
03-20-2017, 11:51 PM | #4 |
Admin Asshole
I'll help out, just a little. Just adding brighter bulbs does NOT make for better lighting. That's really all there is to it.
To see how to properly improve lighting, check out places like ClearCorners.com that specialize in proven methods of improving light output. Taking 1990's headlights and adding brighter bulbs gives you brighter 1990's lighting and nothing else.
03-21-2017, 12:07 AM | #6 |
Admin Asshole
It's not a matter of "not as good" as much as it becomes a matter of scattered useless light because the stock projector isn't designed for it. Also, those "retrofit" kits are pretty crap.
There are quite a few threads on here that discuss lighting, options, and negative effects of using crap parts. Have a look around before making your decision.
03-21-2017, 12:35 AM | #8 |
I'm running 4500k bixenon H4R bulbs in euro hella housings on my 92 with popups. No scattered light, great focusing, and never get flashed or pulled over. The most important thing is to make sure you have the right housings, and that your bulbs will line up properly, otherwise you're not going to see any better, and you'll be like one of those assclowns that blinds everyone else on the road and likely gets ticketed. I know that there are a few good LED kits out there from reputable companies like Sylvania, but you want to make sure that you have the right housings if you're going that route, and PLEASE, for the love of God, make sure your headlights are aimed properly.
Sent from my SM-G935T using Tapatalk
Contributions: ULTIMATE climate HVAC LED conversion. |
03-21-2017, 09:42 AM | #9 | |||
please dont send this guy over to me. he doesnt want to "waste his time" to research something as simple as why you cant retrofit an H4 bulb into an H1 housing, then he is out of luck. Thats like asking how to fit a 2JZ crank into an SR block, its not going to fucking happen. I am not going to help him out. there are so many individuals/shops that specialize in better lighting, contact one of them and pay to have your lights upgraded. |
03-21-2017, 12:21 PM | #10 |
Don't worry, I'm not spending $1,200 on a new pair of headlights. I tried searching the forum regarding HID and LED headlights and looked through the results and couldn't find the exact info I am looking for, so I made this thread. I was pretty clear in my first message. Like I said before, if you have nothing useful to say just don't say anything. Simple as that.
03-21-2017, 06:23 PM | #12 |
I've got HIDs in my kouki projectors. They are 4000k and crystal white and are bright and good. The LED bulbs are really tricky to get good light output, if you are going to retrofit. I experimented with cheap ones from ebay, but for the price of quality LED bulbs you can get HIDs from ddm for your fogs and headlamps. I didnt/wouldnt go that route. Good luck
Sent from mTalk |
03-21-2017, 08:49 PM | #14 |
I just don't think they're going to give out enough light output. The led is a very directional light output, look up about how an led emits light. that's why they have leds on each side of those bulbs. If they're not 360 they're not lighting up every direction. The ones I got were 4 sided with 4 leds on each side, and were not bright enough at night to see 20 feet in front of my car. The hids and halogen lights carry out 50-60 feet all day.
Sent from mTalk |
03-22-2017, 12:52 PM | #17 |
have you checked philips, or IPF
they make some nice LED replacment OE bulbs i am not sure what size bulbs S14 uses, but i am running the IPF H4 LED for headlights, and the cutoff is way better than HID, and easy to install, no mess of relay wires like HID's its pretty much like installing a halogen bulb http://www.usa.philips.com/c-p/78719...d-fog-led-lamp http://www.ipf-light.com/catalog/catalogLedlamp.php |
03-23-2017, 07:59 AM | #18 |
Get them. They will be awesome!!!
03-23-2017, 09:08 AM | #21 |
haha
2017 and people still dont understand why you shouldnt use rebased kits. nah, just buy the h4 kit and then modify it to fit an h1 housing. a dremel will fix all that. :-) |
03-23-2017, 09:27 AM | #22 |
HID is definitely the way to go. Put this kit in my 97 and it looks great perfect clear white and doesn't look cheap or have glare. https://www.theretrofitsource.com/bi...s-stage-3.html
