Old 10-12-2004, 05:35 PM   #1
blackbeltclub99
blackbeltclub99 is an unknown quantity at this point
Send a message via Yahoo to blackbeltclub99
Bucking Problem
Just got my car finished now it bucks like crazy. It will do it pretty much at random, but mainly anytime you are getting off the gas. If you are on the gas it will not do it so take offs are not bad, but as soon as you let off it will start ALMOST all the time. Sometimes it is fine and does not do it. I had it tested for a boost leak and they said their was not one, but thought it may be a TPS problem. if it is the throttle position sensor how do I fix it?
I have a 98 blacktop in a 89 coupe it is almost all stock except for 3"dp, 3" test pipe, 3"catback, 255 walbro, and an intake.
any help would be great...
blackbeltclub99 is offline   Reply With Quote
Old 10-12-2004, 08:11 PM   #2
97SilviaRB
97SilviaRB is an unknown quantity at this point
have you checked the ecu for any codes?
97SilviaRB is offline   Reply With Quote
Old 10-12-2004, 09:03 PM   #3
blackbeltclub99
no, I know I should just search but could you post the procedure?
Old 10-13-2004, 09:50 PM   #4
BillKlineVT
BillKlineVT's Avatar
BillKlineVT is making a name for him/her selfBillKlineVT is making a name for him/her selfBillKlineVT is making a name for him/her self
just out of curiosity, are you running the stock BOV? If you aren't and are venting to the atmosphere, it could be a contributing factor to the "bucking." When I was venting to the atmosphere my car would buck when I was still in gear but off the throttle. Now that I am recirculating the bov, it doesn't buck anymore....
This could have nothing to do with your problem but its just an idea.
-Bill
BillKlineVT is offline   Reply With Quote
