Old 04-01-2017, 12:21 PM   #1
Relentless240
Trader Rating: (50)
Relentless240 is an unknown quantity at this point
Feedback Score: 50 reviews
Spal 16" fan, PBM Swirl pot Gold, Nrg Triangle brace, S14 stuff
Shippin available at buyers expense + paypal fees. Unless stated.
Price reduced.......
Sr20 s14 !ower intake only- 40 picked up
JDM S14 AC Condenser-35 picked up
S14 Gas pedal- 20 shipped
S14 RHD Throttle cable 40 shipped
S14 ebrake (great shape low mileage)-30
S14 BALLER BOLTS Fr Strut bolts- 20 shipped
S14 Master cylinder-20 shipped
AEM Temp Gauge (New Never Use, opened just to inspect)- 160 Shipped
Spal 16" puller fan + fan rubber+Bracket kit- 140 picked up / 160 shipped.
This is Basically new as i only install with idle time only.
This was install on s14 radiator with Ls1 and will fit other applications depending on your set up. This is the curve fan version which is better than the flat fins. Change set up because i plan on running ac.
PBM swirl pot Gold (Brand New)
-SOLD!!
NRG Triangle Brace- 80 picked up / 90 shipped.
Bought it New off another Zilvian. This is to use with the NRG tower strut bar that is sold seperately. Might work with other bars but thats not for sure.
These are use to make the 3rd point (Triangle).
NRG info.....
Add another level of chassis stiffening to your vehicle with the NRG Innovations tri-point bar attachment for strut tower braces. With the triangulation and expansion of force in high-stress point areas of the vehicle, namely the strut-towers, these units dramatically reduce frontal load body flexing and improve overall handling and braking abilities.
300zx NON Turbo " Dr side" Axle (Bought this from japan from someone that thought this was from TT.)- 70 bucks picked up
S14 Fr sway + Oem Endlinks!- 40 pickup
S14 oil reservoir (very clean & white) 40 shipped
S14 Slave cylinder with bracket (came out of low mileage clip) 15 picked up / 22 shipped
Glowshift triple gauge holder 52mm- 15 Bucks shipped
S14 Tanabe Sustec Fr. Lower Brace (Pretty much new Just mounted, og box not shown )-price drop 65 pick up
S14 4 LUG HUBS (REARS ONLY)=30
S14 RHD ABS unit & abs lines- 90
S14 rhd jdm A/C High side line-10
RHD S14 air ducts (Under dash)-7 each
S14 Battery/Ground wire- 7 each
Relentless240 is offline   Reply With Quote
