Old 10-13-2004, 12:07 AM   #1
s14srpilot
s14srpilot's Avatar
s14srpilot is an unknown quantity at this point
Send a message via AIM to s14srpilot
Heat shield for Megan and other test pipes with brackets
Ok, living in Cali is dangerous if you are running a test pipe. Popo's don't need a search warrant to look under the car only to see a shiny test pipe instead of a fake cat.
I also see that some test pipes (such as Megan) have brackets for some type of heat shield. I went to the dealer and tried to look for a heat shield for the catalytic converter (Secondary cat for s14's) and neither the s13 nor s14 has a heat shield on the cat.
My question is: What bolts on to the brackets on these test pipes? Are we to fabricate some type of heat shield? I would feel much safer if the test pipe was covered with a heat shield so that it would look like a cat. Thanks for your input
s14srpilot is offline   Reply With Quote
Old 10-13-2004, 12:14 AM   #2
mrmephistopheles
mrmephistopheles's Avatar
S13s do indeed have heatshields on their cats. Either a.) the person you had looking for a heatshield is mentally deficient, b.) Nissan no longer makes the part, or c.) Nissan never made replacement heatshields.
Originally Posted by PHLIP
Old 10-13-2004, 12:19 AM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
To follow up what Kevin said. Solutions.
a) Ehh. Go back another day, talk to another, not retarded guy.
b) Go to a junkyard and get one, and/or post in WTB section.
c) See above.
-Jeff
Whatup?
Jeff240sx is offline   Reply With Quote
Old 10-13-2004, 08:29 AM   #4
s14srpilot
s14srpilot's Avatar
That is weird. I had the guy print out a picture of the exploded view of the exhaust system for both the s13 and s14 and i did not see a heat shield for the cat on either model. The s13 I looked at was a '92. Perhaps they were on the 89-90 models? Either way, option b seems like my best bet. Thanks
Old 10-13-2004, 03:36 PM   #5
kandyflip445
kandyflip445's Avatar
I know there is a heatshield mounted to the bottom of the chassis on my 91'.
My 240 vBgarage
Old 10-13-2004, 03:47 PM   #6
Andrew Bohan
on mine too
Old 10-13-2004, 06:05 PM   #7
mrmephistopheles
All S13s had heat shields. What it may well be is in a parts group. Meaning you might have to buy a whole new cat (very pricey) in order to get a new heatshield.
Old 10-13-2004, 06:09 PM   #8
ryan hagen
ryan hagen's Avatar
ryan hagen is making a name for him/her selfryan hagen is making a name for him/her self
he is looking for one that wraps around the cat, we all have one bolted too our chasis but it doesnt bolt to the cat, he wants something to make his test pipe look like a cat. best bet is to find one form soemthing else, or hollow a cat out and weld a pipe into it, thats what i did............looks like a factory cat, but its a 2 1/2" test pipe.
my cat had no heat shield, niether did my s14 or s13 parts car, i just check my buddies 91 coupe and it jus thas a rusty ass cat like mine, the only s13 i have seen with a heat shield covering the cat was my friends 92 parts car with a after market cat. i am positive he isnt talking about the heat shield attached to the car but one that cover the cat top and bottom............
1990 hatch ka24de gt2871r
ryan hagen is offline   Reply With Quote
Old 10-13-2004, 07:33 PM   #9
black s13
black s13's Avatar
black s13 is an unknown quantity at this point
Send a message via AIM to black s13 Send a message via Yahoo to black s13
my s13 had one, until it rusted off.
black s13 is offline   Reply With Quote
Old 10-13-2004, 08:39 PM   #10
S14DB
AFC #1
S14DB's Avatar
It's best to buy a S14 hollow cat from someone like me.
Old 10-13-2004, 09:33 PM   #11
psidriven
psidriven is an unknown quantity at this point
s13 definately have a heatshield on the cat. i bought a vision test pipe with the brackets and used the stock heatshield on it. this is on a 89 base model hatch.
psidriven is offline   Reply With Quote
Old 10-13-2004, 10:10 PM   #12
element240
element240's Avatar
element240 is an unknown quantity at this point
Send a message via AIM to element240
i'm still wondering what the brackets on the megan test pipe is for (havent installed mine yet) , i went underneath the car, and it doesn't look like it can bolt to anything.
element240 is offline   Reply With Quote
Old 10-13-2004, 10:14 PM   #13
s14srpilot
s14srpilot's Avatar
Nice try. That fake cat is the only bottleneck in my exhaust because it is 2.5" and the rest of my exhaust is 80-85mm.
Old 10-13-2004, 10:17 PM   #14
S14DB
AFC #1
S14DB's Avatar
Looks real.
and is straight thru
Old 10-14-2004, 12:55 AM   #15
Jeff240sx
I hate you too...
Jeff240sx's Avatar
It's egg-shaped. Bad for flow.
-Jeff
Whatup?
Old 10-14-2004, 01:02 AM   #16
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
What you do is punch it and then get a 63mm ( I think) pipe and cut it to lenght and the pund it into the cat and the take a dremel and port it smoothe so there is no lip and voila you have a straight cat. it is done quiet often.
silviasichigo is offline   Reply With Quote
Old 10-14-2004, 01:15 AM   #17
S14DB
AFC #1
S14DB's Avatar
-Jeff
...and that's why it's not on my car anymore. I love FL!
