Old 05-03-2017, 02:47 PM   #1
Johnny Coquí
Johnny Coquí is an unknown quantity at this point
s14 1JZ non vvti for sale with turbo manifold
A little history on the motor.
I brought the motor from a guy named Mike Moretti on the JZ groups. It was his spare motor Nothing wrong with the motor I took the turbos off because I was going single turbo.
Basically what I was going to do was refresh the whole motor before swapping it in and buying a harness and standalone but I found a dd I want so I've decided to put this up for sale.
NO HARNESS OR ECU
-1JZ short block
-1JZ front sump oil
Pan
-1JZ fuse fabrication T3 Turbo Manifold
-2JZ water pumps
-2JZ Oil pump
-NST Alt, WP, PS, & Tensioner Pulley
-Ross Tuffbond Metal Jacket Crank Pulley
-1JZ Alternator
-1JZ starter
-2 1JZ Cam Seals (Non-vvti)
-1JZ Timing belt idler pulley
-1JZ Front main seal
-1JZ Rear main seal
-1JZ Thermonstat
-2 1JZ timing belt guide
-2 1JZ timing belt hydraulic tensioner
-1JZ valve covers
-1JZ intake manifold
-Tomei cam gears
Cam, crank, and rear main seals were done, oil pan was resealed with new bolts
$3000 obo
Located in orlando fl
prefer a local sale
Johnny Coquí is offline   Reply With Quote
Old 05-05-2017, 08:22 AM   #2
Johnny Coquí
bump to the top
Old 05-06-2017, 09:15 AM   #3
Johnny Coquí
Bump to the top
Old 05-08-2017, 08:57 PM   #4
Johnny Coquí
Bump to the top
Old 05-10-2017, 09:55 AM   #5
Johnny Coquí
bump to the top
