![]() Join Date: Oct 2003
![]() I recently swapped an s13 blacktop into my 97. After fixing my faulty MAF wiring(doh) the car is running ok. However the idle fluxuates from 1100-900RPM while sitting, if i rev the motor high and let off, the idle will drop to 300-400 and come back up. When im driving the car it stalls CONSTANTLY. If I let the idle fall to low it will just die.
Also i've read somewhere a faulty coolant temp sensor giving incorrect readsing could screw with your idle. I didn't swap the KA sensor with the SR sensor since my friend sort of broke it. Could this be causing my problem? |
![]() Join Date: Oct 2004
Good luck with everyting! Post some pics up. This Winter ill be working on mine. Hope everything goes well.
Drift Indy |
that sounds a lot like what my car was doing. i had a bad mafs and i swapped coolant temp sensors just for fun. try turning up the idle a bit too. i also have safc and boosting the fuel helped a bunch. good luck.
booooooost leak. my god damn BOV was leaking like woah, i slapped in a solid pipe and the car runs MINT. only problem is i dont want to boost till I get a new BOV cause im afraid ill fuck up the turbo, i heard running a little boost without a BOV will be OK. I have TONS of pictures I will be posting soon. Anyone selling a HKS BOV =]
#8 | |
#9 |
![]() Join Date: Aug 2003
![]() ![]() ![]() ![]() Feedback Score: 2 reviews
i have no idea what kind of hot pipe your using but maybe you could use a DSM BOV or a supra one or somthing from a junkyard unless your getting your BOV soon...
89 240sx hatch #933-the hot rod 91 240sx coupe #131,603-the daily |
#10 |
DSM BOVs are junk... my friend had to crush his just so it would hold 7psi, and I think it was still leaking.
http://www.atpturbo.com/ bomb-ass BOVs yo. statik: How did you mess up the MAFS wiring? |
