Old 07-12-2017, 11:02 PM   #1
idae209
idae209 is an unknown quantity at this point
Arrow 1995 Lexus SC300 Factory 5 Speed
Salvage title due to fender bender, bought off of a Toyota Tech who owned it for the past 15 years. 205k original engine and transmission, daily driven but mostly freeway miles. I have made 4 ten hour trips to Arizona and back to Northern California with no issues.
Mainly looking for a 240sx s14 or $4,500 obo
The following parts were replaced in the last few years : motor mounts,trans mount,clutch, machined flywheel,lower control arms,all 4 struts,swaybar bushings,power steering rack,lines,and pump all done within last 8k miles, prior to 190k. Timing belt, tensioner, waterpump, valve cover gaskets, plugs , cap , rotor, wires, vacuum hoses, oil filter housing o ring, and radiator all replaced within last few years. Recently replaced harmonic balancer, belts, and radiator fan.
Aftermarket modifications: Stance SuperSport coilovers 18kg/12kg, Hayana Motorsports Mufflers, HIC Rear Window Visor, stock wheels!
I can send more photos via email or text, currently unable to upload most of my images as the file size is too large even after saving as a lower resolution..
idae209 is offline   Reply With Quote
2jzge, sc300, soarer, w58
