Old 09-10-2017, 11:52 PM   #1
Fastka24de
Fastka24de is an unknown quantity at this point
97% finished s13 built ka24de project !! Must look
What's up, I'm here selling my pride and joy project a lot of blood, sweat, tears were made car is 97 % done you judge it.
Unfortunately , I need to sell because I'm opening up a business and need the money!! No trades or part outs!
Location Sacramento
BC h-beam rods
ARP 2000 bolts
CP piston 9:0:1
CP piston rings
ARP head studs
ARP main studs
248/248 cams
Re drilled cam gears
Xcessive Intake manifold
Custom fuel rail with fittings
FID 1000ccd injectors
FID pig tails
Xcessive upper oil pan
REV 9 Sr20 over sized lower
Doc racing exhaust manifold
Tomei 1.2mm head gasket
Celveite rod and main bearings
NGK Spark plug wires
NGK PLUGS
NEW OIL strainer
ALL BRAND NEW SENSORS
ALL OEM PARTS
ALL NEW Gaskets
NEW water pump
NEW OEM belts
NEW water neck
NEW oil pump gear
NEW front main seal
NEW rear main seal
NEW Distributor
New timing chain kit
Mr copper exh gasket
P2m thermal intake gasket
Cx racing radiator
Cx racing E fans
Cx racing RaD hoses
ISR fuel pressure regulator
Mishimoto coolant over flow
Mishimoto PS revisor
Summit racing An fuel line kit
P2m motor mounts
Trans :
SR trans with KA housing
Spec stage 3+ clutch
ISR short shifter
BLOCK :
*Fully balanced rotating assembly with the crank pulley
*Polished crank
*Block was honed to Piston spec
*Surfaced
*Align honed
*Rings were file fitted
** Piston and Rod combo weighs 1.9 grams from each other**
HEAD INFO:
Fully rebuilt head
*Machined head
*3 angle valve job
*New seals
Motor is a s14 but with s13 accessories
ALL PARTS ARE BRAND NEW HAVE PAPERWORK FOR almost EVERYTHING.
89 240sx shell
Clean title
Reg expired last year
Welded diff
Non cracked dash
S14 seats
Full interior
Megan track coils
Pretty straight
Comes with full front end
Wheel wells cut ready for tubs
Some less shwab wheels with new tires
Looking for 5500 obo
Only trade I would be interested in is vh45 swap 240
55+ pictures can't upload I don't know why
Email me [email protected]
Fastka24de is offline   Reply With Quote
