Old 10-21-2004, 10:02 AM   #1
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
Did my motor come with cams or what?
My motor idles really weird, almost like its missfiring sometimes. Timing is 20 degrees, my friends sr had timing of 35 and it idled fine. My car is WAYYY faster then his on the same setup and feels like it pulls harder in higher rpm sometimes. Could i have cams and not know it? My motor came in the front clip with a new clutch.
sepulchral is offline   Reply With Quote
Old 10-21-2004, 10:14 AM   #2
autobahNESSA
autobahNESSA's Avatar
autobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfectionautobahNESSA is close to perfection
Send a message via AIM to autobahNESSA
Isnt timing suppose to be 15 deg. btdc? Ya if your friend has 35deg. timing no wonder your faster.
autobahNESSA is offline   Reply With Quote
Old 10-21-2004, 10:25 AM   #3
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Timing SHOULD be 15 Deg btdc.
What you want is ignition base timing.
You're checking timing with ecu in control
Simple,
Warm engine up,turn motor off, disconnect TPS ( throttle position sensor) with engine off, start up engine, check timing with gun, play with the CAS ( crank angle sensor) set to 15 deg, secure CAS, snap throttle ( quick rev), let idle .. adjust idle if needed via IAA on intake manifold.
Kid Zelda is offline   Reply With Quote
Old 10-21-2004, 02:34 PM   #4
Andrew Bohan
you engine wouldn't work at all if it didn't have cams....
if you wanna check what cams you have, take off the valve cover and look
Old 10-21-2004, 04:23 PM   #5
Muzzy
Muzzy's Avatar
Muzzy is an unknown quantity at this point
Send a message via AIM to Muzzy Send a message via Yahoo to Muzzy
lol you're joking right driftaholic??? u are jus takin his question literally and screwin with him rite?? ..i hope so
lemme have a dollar
Muzzy is offline   Reply With Quote
Old 10-21-2004, 04:41 PM   #6
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
my engine came with cams, a turbo, an intercooler, all types of cool stuff. everynow and then someone will get aftermarket performance parts =O
wootwoot is offline   Reply With Quote
Old 10-21-2004, 08:27 PM   #7
WeldingHank
WeldingHank is an unknown quantity at this point
my CA came with an HKS accuator. and i am still suspecting a set of aftermarket cams.
WeldingHank is offline   Reply With Quote
