Old 10-03-2017, 10:51 PM   #1
Brandon240sx
Brandon240sx's Avatar
Brandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choicesBrandon240sx has made poor choices
5 speed swap
I’m finally at the point of being ready to swap my 5 speed tranny into my auto s13. My question is, what parts would be smart to replace with brand new parts while the tranny is out of the car to save me headaches in the future? As of right now, I have everything I need to put the tranny in but All of those parts are used.
Brandon240sx is offline   Reply With Quote
Old 10-04-2017, 12:26 AM   #2
TheRealSy90
TheRealSy90's Avatar
Resurface the flywheel.
Get a new clutch and pressure plate.
New pilot bushing/bearing in the crank.
New upgraded clutch fork pivot ball.
New throwout bearing.
Should be good from there if the slave and master are functional, might as well do a new slave if you can.
Such a good signature.
Old 10-04-2017, 06:33 AM   #3
Phlip
Yes, I look like that
Phlip's Avatar
^^^ What he said
I used a ton of used parts that had recently come right off of another car and got lucky, but I wouldn't suggest doing that if I knew better than I did back then.
Weirdo
And I write too!
Old 10-04-2017, 04:56 PM   #4
Brandon240sx
Alright awesome thanks for the help guys
Old 10-04-2017, 05:19 PM   #5
blasian
blasian is an unknown quantity at this point
Get a aftermarket trans mount, go poly or rubber.
blasian is offline   Reply With Quote
Old 10-04-2017, 05:32 PM   #6
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
please do not re use your trans fluid.
im sure you already plan on changing, but I saw someone not that long ago reuse their old nasty trans fluid and it was bad.
jumpman2334 is offline   Reply With Quote
Old 10-04-2017, 05:36 PM   #7
Brandon240sx
What could possibly go through someone’s head to make them think that was a good idea?
Old 10-04-2017, 06:38 PM   #8
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
SEALS: rear main seal (check or replace) and same with the output seal on the trans.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 10-04-2017, 07:17 PM   #9
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Don't replace something that is not broken because there is a higher chance of you breaking/incorrectly installing something than that part breaking naturally.
Ilya is offline   Reply With Quote
Old 10-25-2017, 12:25 AM   #10
Brandon240sx
I’m guessing basic stuff like seals, pivot ball, pilot bushing, pilot bearing, and throwout bearing wouldn’t be something that can be easily messed up and since the tranny isn’t in the car yet, might as well replace those to avoid shit in the future
Old 10-25-2017, 07:53 AM   #11
Ilya
Ilya's Avatar
Have you ever tried taking out the rear main seal housing? It's a bitch on an engine stand, even worse when the engine is in the car.
If it's not leaking, don't replace it. This is not the only time you will have the transmission out.
Old 10-25-2017, 10:51 AM   #12
Brandon240sx
Nah I never tried had no idea, thanks bro
Old 10-25-2017, 12:23 PM   #13
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
lol its actually easier in the car because there's nothing in the way when the trans is off
pacotaco345 is offline   Reply With Quote
Old 10-25-2017, 06:50 PM   #14
TheRealSy90
I forgot about the pivot ball, get the new "upgraded" one that tons of companies sell.
The stock ones are known to snap.
Old 10-25-2017, 07:31 PM   #15
Brandon240sx
Wish I read this a few mins earlier, just got done ordering a new OEM clutch pivot ball, just Bc I’m sure the one on my tranny has seen a beating. A new pilot bushing, throwout bearing, a new master and slave Bc why put the old ones in when new ones are so cheap, and an isr SS auto to manual line to bypass the clutch dampener.
Rear main seal I’m just not touching because it’s not leaking and if I install a new one the wrong way, then I’d have to drop the tranny again to replace it. I’m putting a resurfaced flywheel in and a used clutch since I had it sitting around and it seems like it has decent life left. Kinda figure by the time i need a new clutch I’ll take care of it then.
Old 10-25-2017, 10:12 PM   #16
TheRealSy90
You'll be fine either way. Honestly all the pivot balls that break most likely have over 100k miles on them. A new OEM one should work fine if you are using an oem style clutch and pressure plate. When you upgrade to something with more clamping force I'd go with the thicker pivot ball.
Old 10-27-2017, 11:37 PM   #17
Brandon240sx
Got ya, thanks bro
