Old 10-21-2017, 06:38 PM   #1
Kouki1998
Kouki1998 is an unknown quantity at this point
KA HELP! Car won't turn over
So I just replaced my engine harness with an engine harness from wiring specialties (ka24de). The car cranks but won't turn over. The car was running before I changed the harness, my 240 is a 1998 kouki with an engine out of a 1996 zenki, any help is appreciated!
Kouki1998 is offline   Reply With Quote
Old 10-21-2017, 06:40 PM   #2
nisileighty
nisileighty's Avatar
nisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of lightnisileighty is a glorious beacon of light
Did you connect the dash plug?
nisileighty is offline   Reply With Quote
Old 10-21-2017, 06:51 PM   #3
Kouki1998
What dash plug ??? I'm sure I connected everything and if something is disconnected it's probably because the connector is different.
Old 10-21-2017, 06:58 PM   #4
nisileighty
Remove your glove box. 2 8mm interior screws on the bottom and there’s a brown plug on the right make sure that’s plugged in or else nothing will work.
If it is plugged in, make sure your starter and alternator are hooked up. There should be a black w/ yellow stripe wire going to the starter as a start signal. Make sure that’s hooked up. It’s really common that those come disconnected.
Old 10-21-2017, 07:11 PM   #5
Kouki1998
That brown connector ? It wasn't connected before, could it be that the harness has a different relay?
Old 10-21-2017, 07:11 PM   #6
Kouki1998
http://imgur.com/vLJ6mmt
Old 10-21-2017, 07:15 PM   #7
nisileighty
That brown plug needs to be plugged in. That has tach signal, start signal, speed signal, etc.
Old 10-21-2017, 07:18 PM   #8
Kouki1998
Dude I have no connectors that fit the brown connector! It wasn't even plugged in with my old engine harness
Old 10-21-2017, 07:19 PM   #9
nisileighty
Does your ecu turn on when you turn the key?
Old 10-21-2017, 07:28 PM   #10
Kouki1998
I'm guessing no because the check engine light went away
Old 10-21-2017, 07:45 PM   #11
nisileighty
Don’t use the check engine light. Check the LED on the actual ecu itself.
Old 10-21-2017, 07:55 PM   #12
Kouki1998
My ecu doesn't have an led light or it doesn't work
240sx, harness, kouki, nissan, s14
