C33 Rb25 swap
Hello all, I’m about to do a Rb25 swap on my 91 c33 laurel. I’m posting this in hopes for information on the swap.
Alright, details of the car now: Rb20e Automatic What’s going in the car: RB25det series 2 Rb25 transmission Needed Information: So when I bought this swap, it came with s13 engine mounts and transmission crossmember/Mount and a 1 piece steel driveshaft for Rb25 tranny in a s13. I need to know if those s13 mounts will work? I know for my motor mounts, I can use my stock rb20e mount but for tranny crossmember/mount, do I use the stock c33 auto mount? Can someone shed some light on which mounts? What about the driveshaft? Will that work? I think it’ll need to be lengthened but I’m not sure. Also, will the stock Rb25 s2 engine harness plug straight into the laurel or do I need to do some wiring or get a harness? Thank you all and I look forward to getting some solid info spread out. |
![]() Join Date: Aug 2009
![]() Feedback Score: 9 reviews
You will keep the RB front member and engine mounts ( I would upgrade to Nismo) and need manual R32 trans mount. Keep that shaft and have it modified to fit, front yoke I think for the 71C RB trans.
Wiring relays I think diff plugs inside car. |
Also, while we are at it, let’s see if we can shed some light on a manual swap in a c33 laurel. As far as the clutch pedal goes, can I use a lhd s13 clutch pedal assembly? Or do I need to use a r32 or Rhd s13 clutch pedal assembly? Thank you all!
