Old 12-15-2017, 05:49 PM   #1
cclark
cclark's Avatar
cclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choicescclark has made poor choices
1997 LS JUAN (LS1) Kouki Build
Car was purchased in June 2017, and is now running, tuned and driving as of November 2017.
Instagram: _lsjuan_
1997 Nissan 240sx LE
Silver Moss
Automatic
Special thanks:
Motor/Transmission
2002 LS1 & T56 – 114k Miles
Mishimoto Aluminum Radiator and Fan Shroud
Mishimoto LSx Swap Hoses
Mishimoto Coolant reservoir tank
Mishimoto Water Temperature Sensor Adapter (for LS Steam port)
NGK Iridium Spark Plugs
MSG Super Conductor Spark Plug Wires
GM LS1 Corvette Fuel Rail Covers
GM LS7 Clutch, Pressure Plate, Flywheel
Texas Speed LS1 Camshaft: 228/228 .600/.600 112 LSA 110 ICL
New valve Springs & Pushrods
New LS GM Oil Pump
New LS2 Timing Chain
New LS1 Water Pump
ARP LS1 Head Studs
ARP LS1 Flywheel Bolts
New TSP Rear Main Seal
New LSx Rear Cover Gasket
New GM LS1 Head Gaskets
Taylor Battery Box and battery relocated to trunk
Battery Box Breaker switch
Sikky Motor Mounts
Sikky Oil Pan
Sikky Driveshaft
Sikky Ceramic Coated Headers
Sikky Oil Relocation Kit
Sikky GM Fuel Filter Kit
Sikky Angled Shifter Rod
Wiring Specialties Swap Harness
Wilwood Clutch Master Cylinder
HKS Hi-Power Cat Back Exhaust
Custom Y-Pipe: EFI Logics
Walbro 255 Fuel Pump
JL Design & Fab Fuse Box cover w/ s14 Silvia Logo
JL Design & Fab Radiator Supports w/ s15 Silvia Lightning Bolt
Tomei 1.5 Diff in s14 Pumpkin
Suspension
Fortune Auto Coilovers
DIF Solid Rear Subframe Bushings
Parts Shop Max dual caliper rear knuckles
ISR Front Tension Control Rods
ISR Rear Traction Rods
ISR Rear Toe Control Rods
ISR Rear Upper Control Arm
Sikky Sway Bar Front w/ Sikky End links
Parts Shop Max Dual Caliper Knuckles
Nismo Front Strut Bar
Nismo Rear Strut Bar
Nismo Rear Sway Bar
GKTech Rear End Links
Wheels & tires
Muteki Lug Nuts
Rays 57CR Gramlights (18x9.5 & 18x10.5)
Hankook v12 Tires
Brakes
Z32 Master Cylinder
350z Front Calipers - Powder Coated Teal
z32 Aluminum Dual Calipers - Powder Coated Teal
EBC 350z Front Rotors
EBC Z32 Rear Rotors
ASD Pull Up Hydraulic ebrake and lines
DIF z32 Stainless Brake Line Conversion (Front & Rear)
New OEM Nissan 5 lug Front Wheel Bearings
Chase Bays In-Bay Brake Lines
Interior
S15 Spec R Blue Suede Seats/270r Authentic Seats
Flocked Dash
Flocked Center Console
LRB Speed Radio Climate Control Dash Filler
LRB Speed Door Cards (wrapped in suede)
LRB Speed Dash Vent
Nismo Steering Wheel Boss
Nardi Deep Dish Steering Wheel
Reupholstered Rear Seat black cloth w/ black suede inserts
Custom leather ebrake shift boot
Authentic 240sx Floor Mats
Exterior
Repainted Ford Frost White w/ House of kolor lazuli blue pearl
Authentic Ganador s14 Mirrors w/ Blue Glass
JDM Glass Headlights
DMAX Corner Lights
DMAX Tail Lights
Gent5 Clear bumper lights
Nissan OEM Rear Bumper
Greddy Front Lip
OEM Side Skirts
JDM OEM Front Bumper
JDM OEM Rear Bumper
JDM OEM Rear Bumper Spats
Custom Painted Teal Engine Bay
NRG Radiator Shroud
Shaved Antenna
Shaved Windshield Washer Fluid Squirters
Shaved front license plate holes
Shaved front emblem
Rolled and Pulled fenders
And it starts...
Pulling the stock Motor and Trans...
Cleaning the bay...
Painting the bay..
Color matched the calipers...
Preparing the LS...
Mounted wheels and tires...
cclark is offline   Reply With Quote
Old 02-27-2018, 09:37 AM   #2
eastcoaststeeze
eastcoaststeeze is an unknown quantity at this point
where are the painted car photos
eastcoaststeeze is offline   Reply With Quote
Old 02-27-2018, 09:40 AM   #3
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Looks good, very similar to my setup.
afishysilvia is offline   Reply With Quote
Old 02-27-2018, 10:04 AM   #4
mewantkouki
Trader Rating: (36)
mewantkouki will become famous soon enoughmewantkouki will become famous soon enoughmewantkouki will become famous soon enough
Feedback Score: 36 reviews
You're going to hate those tires. lol
mewantkouki is offline   Reply With Quote
Old 02-27-2018, 01:50 PM   #5
eagleeyes221
eagleeyes221 is an unknown quantity at this point
ayy a local guy from CT. the build looks pretty good so far
eagleeyes221 is offline   Reply With Quote
Old 02-27-2018, 02:07 PM   #6
Benfica7
Benfica7's Avatar
Benfica7 is an unknown quantity at this point
Subscribed for a fellow New Englander!
Benfica7 is offline   Reply With Quote
Old 02-27-2018, 03:59 PM   #7
cclark
cclark's Avatar
Meh...
Sent from my SM-G950U using Tapatalk
Check out my build: https://zilvia.net/f/showthread.php?p=6248522
Old 02-27-2018, 04:10 PM   #8
cclark
cclark's Avatar
Really bad??
Old 02-28-2018, 06:30 AM   #9
cclark
cclark's Avatar
All painted and sitting tight until the spring!
Old 02-28-2018, 06:31 AM   #10
cclark
cclark's Avatar
Old 02-28-2018, 08:40 AM   #11
eastcoaststeeze
do a burnout
Old 02-28-2018, 12:50 PM   #12
eastcoaststeeze
Old 02-28-2018, 12:53 PM   #13
afishysilvia
Trader Rating: (31)
Interested to see how hot your fuel filter setup gets right there, that is awfully close. Clean looking setup though. All stock internals? What are dyno numbers?
Old 02-28-2018, 02:26 PM   #14
cclark
cclark's Avatar
yeah...the Sikky Swap kit is designed to mount on the inside of the strut tower...that literally put the hardlines right next to the manifold. In the current position, I have the lines bent away from the header. If it gets too hot, I'll figure something else out..
Mustang Dyno: 368 HP/ 384 tq
All stock internals except for the cam
Old 02-28-2018, 02:44 PM   #15
240sex_s14
240sex_s14's Avatar
240sex_s14 is making a name for him/her self240sex_s14 is making a name for him/her self
Send a message via AIM to 240sex_s14
noooooo!!!!! you should have kept the kr5 color >.<
Check out my Build Thread!http://zilvia.net/f/showthread.php?t=650464
240sex_s14 is offline   Reply With Quote
Old 02-28-2018, 02:53 PM   #16
afishysilvia
Trader Rating: (31)
Very nice numbers for stock, I have similar setup with GM hot cam, corvette injectors and forged internals however no tune yet. I am using the Sikky short lines kit to on the strut tower and have had to put shielding over the filter, my plan is to relocate it soon cause damn my car temps heat up. I have three fans going to keep it cool, I also have AC and all the other crap in front of my radiator.
Old 02-28-2018, 03:38 PM   #17
cclark
cclark's Avatar
It needed a paint job...house of Kolor pearl white was the dream
Old 03-01-2018, 07:13 AM   #18
eagleeyes221
Id recommend using fire sleeve. I used that on my setup for both the fuel and oil lines that pass near the headers.
Old 03-01-2018, 08:58 AM   #19
cclark
cclark's Avatar
Good call - I'll look into it - thanks!
Old 03-05-2018, 04:31 PM   #20
cclark
cclark's Avatar
You know you're doing something right when you change the minds of non-schassis owners...
Old 03-06-2018, 10:02 AM   #21
afishysilvia
Trader Rating: (31)
So much suede...too much sauce I like it.
Old 03-06-2018, 04:07 PM   #22
cclark
cclark's Avatar
Hah indeed
Old 03-07-2018, 10:55 AM   #23
deolio
deolio's Avatar
jesus christ that engine bay color. are you 12?
Old 03-07-2018, 11:05 AM   #24
afishysilvia
Trader Rating: (31)
Haha damnit...here we go.
OP, did you also purchase the LRB undertray? Im interested in it for my car but havent heard to much of them other than your post and another build on here.
Old 03-07-2018, 11:08 AM   #25
240sex_s14
240sex_s14's Avatar
H8T3RS Gon H8!
Old 03-07-2018, 12:00 PM   #26
cclark
cclark's Avatar
H8T3RS Gon H8!
Hahah love it!
Old 03-07-2018, 12:03 PM   #27
cclark
cclark's Avatar
Hahah love this forum, it's quite hilarious
I didn't get the LRB Undertray, it only fits Zenki's (according to the site) and I have no idea how it would fit with the Sikky LS oil pan...
The other parts that I have are awesome, Landon and his wife, Rebecca, make these parts themselves in Florida and they fit super well.
Old 03-07-2018, 12:08 PM   #28
afishysilvia
Trader Rating: (31)
Very cool, I will have to get into contact with them. I have the CX kit and it sits about the sway bar so I would assume it should fit. I need to force air through my bay. I'm interested in the temps you'll be seeing on your swap. I recently moved my intake filter into the bumper, I had it like yours and my IAT's were way too high.
Old 03-07-2018, 02:41 PM   #29
cclark
cclark's Avatar
Let me know how that goes, and yeap - I haven't really put too many miles on this thing yet...ton of snow in CT, and the salt on the roads is not ideal. I'll keep you posted.
Old 03-08-2018, 06:58 AM   #30
eagleeyes221
+1 on having the filter in a box. before the filter box my IAT was around 180. I made a quick box out of fiberglass and sealed it off from the rest of the bay. It brought the IAT down to around 110-120.
drift, kouki, ls1, silver moss
