![]() Join Date: Jan 2002
Howdy! I was looking at some 9.5" wheels for the front & rear... I was just wondering if that offset would be right. Seems like they'll end up sticking out with that deep of an offset. Please help me out!!
Thanks, Jeff
1998 240SX SE 5-Speed |
Yep- WAY OUT. I wouldn't think you could even run them... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/crazy.gif" border="0" valign="absmiddle" alt=':crazy:'>
Zilvia Contributor
![]() Join Date: Oct 2001
![]() ![]() Feedback Score: 1 reviews
This represents a tire on a rim (looking at it from the tread side) , thats hooked to the axlel. The "H" represents where the rim bolts to the hub. The further the "H" is to the right, the deeper the rim is. The further the "H" is to the left, the deeper the tire will stick toward the gastank.
(- - - -H- - - -) (zero offset) |- - - -H- - - -| |- - - -H- - - -| |- - - -H- - - -| |- - - -H- - - -| ----------------- |- - - -H- - - -| ----------------- |- - - -H- - - -| |- - - -H- - - -| |- - - -H- - - -| (- - - -H- - - -) (- - -H- - - - -) (positive offset) |- - -H- - - - -| |- - -H- - - - -| |- - -H- - - - -| |- - -H- - - - -| ------------------- |- - -H- - - - -| ------------------- |- - -H- - - - -| |- - -H- - - - -| |- - -H- - - - -| (- - -H- - - - -) (- - - - -H- - -) (negative offset) |- - - - -H- - -| |- - - - -H- - -| |- - - - -H- - -| |- - - - -H- - -| -------------------- |- - - - -H- - -| -------------------- |- - - - -H- - -| |- - - - -H- - -| |- - - - -H- - -| (- - - - -H- - -) If you went with the +20 offset (versus the +35 the 240 is supposed to have) your tire will be slightly closer toward the direction of the differential....15mm to be exact. I doubt this would rub...but....if you change the offset too drastically, it could change the cars factory handling, probably for the worse.
400x200 ![]() |
#5 |
Sure... but doesn't the offset also depend on the width of the wheel... because taking that the midpoint of a 8" wheel is 4" and the midpoint of a 10" wheel is 5" on the 8" wheel with a offset of +35mm would be equal to a 10" wheel with a +60mm because in order for the wheel to be flush with the fender the bolts would have to be further into the wheel... although it may just be that I don't understand how offsetting works.
(- - -H-/- - - -) (18x8 wheels +35 Offset) |- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| ------------------- |- - -H-/- - - -| ------------------- |- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| (- - -H-/- - - -) Notice the distance between the center and where it should bolt has been increased.. it seem that since the wheel is two inches bigger, in order to be in the same place as the +35 8" wide wheel you'd consider you start at 5" instead of 4" and since there are about 25mm (roughly) in an inch ... add 25mm Is that how offsetting works? (- - -H- -/- - - -) (18x10 +~60mm) |- - -H- -/- - - -| |- - -H- -/- - - -| |- - -H- -/- - - -| |- - -H- -/- - - -| -------------------- |- - -H- -/- - - -| -------------------- |- - -H- -/- - - -| |- - -H- -/- - - -| |- - -H- -/- - - -| (- - -H- -/- - - -) Jeff
#6 |
you got it man! That's why wider wheels off more negative off sets. Being flush with fender you need higher offset? nah man, the stock wheels have maybe an inch into the fender. Plus for an s13, the widest you can go is probably 9's with 25 offset or something.. I want my wheels to stick out more, it would look a lot better. I probalby get 7.5 +32, and 8.5 +32 in front and back.. hopefully that'll work.
K. Lu |
#7 |
WOW addicted
![]() Join Date: Dec 2001
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I've heard the widest you can go is 8.5 in the front w/o rubbing, so you might want to check on that. I've seen 9.5 in back on S14, but it was close. Not sure about differences in S13 vs. S14.
#9 |
Zilvia Contributor
|- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| ------------------- |- - -H-/- - - -| ------------------- |- - -H-/- - - -| |- - -H-/- - - -| |- - -H-/- - - -| (- - -H-/- - - -) (- - -H-/- - - - -) (18x10 wheels +60 Offset) |- - -H-/- - - - -| |- - -H-/- - - - -| |- - -H-/- - - - -| |- - -H-/- - - - -| ------------------- |- - -H-/- - - - -| ------------------- |- - -H-/- - - - -| |- - -H-/- - - - -| |- - -H-/- - - - -| (- - -H-/- - - - -) (dunno if they even make +60 offset tho) I dont think the rim gets thicker in the middle (as your 18x10 diagram shows)...that would require longer bolts on the hub. If you want anything wider than 9 inches, get something 15 inch thru 17 inch. Personally I like those drifter rims that are like 16x10 in rear. Those shouldnt rub the fenders, and would look sweet if slightly lowered in the rear..and used with JUN fender flares. m
400x200 ![]() |
