Old 05-04-2018, 02:38 PM   #1
joeapple8
joeapple8's Avatar
Trader Rating: (32)
joeapple8 is an unknown quantity at this point
Feedback Score: 32 reviews
SR20VET RWD - S13 Block P12 Head - Engine Assembly by Blue Moon Performance
SOLD
No Trades! No Part outs!
I've ran into some financial issues and need to start over.
I've come to the conclusion that I will be selling everything s-chassis related so you will see my car up for sale within the next couple of days.
I will never create a gofund me to fund my hobbies or mistakes.
Labor and assembly by @bluemoonperformance
WPC treatment by @bluemoonperformance
SR20VE RWD conversion
S13 Redtop block
P12 Primera SR20VE head - Brand New
P12 XTrail Cams - Turbo cams
Supertech stainless steel intake valves NEW
Supertech iconel exhaust valves NEW
SR20VE CP pistons NEW
Tomei adjustable cam gears x2NEW
Tomei metal head gasket NEW
Tomei forged H beam connecting rods NEW
Mazworx modified oil pickup NEW
Tomei oil pan NEW
Ross Tuffbond harmonic balancer NEW
Taarks HALL effect sensor NEW
Taarks timing positioning marker NEW
Taarks VVL oil feed NEW
Narprec Strengthenthed timing chain NEW
Mazworx timing chain threaded oilier NEW
ENGINE ASSEMBLY - Overhaul -
Disassembly Used Engine,Clean & inspect All Parts,
Replace Pistons,rings, Conecting Rods, main and rod
bearings, Check & Rapping crankshaft and camshaft.
clean and test or replace
Block Machine Work
Fix & Rebalance Crank shaft,CNC Cylinder bore
for oversize piston used torque Plate,Deck straight
block.
Head Work
Valve Grind Complete - Replace All
Valves Reamed & hone guides for Fit to New
Valve sterns[5.5mm-6.0mm],
Install SPL valve stem seals,resurface Deck,replace springs, resurface
valve seats, replace camshaft,clean inspect & install
used rocker arms, adjust valves
WPC Metal Surface Treatment
Piston - Dia.3.40" X4
Piston Ring - Top,2nd & Oil full set (4pc) X4
Piston Pin X4
Con-Rod Steel X4
Bearing - Rod X4
Bearing - Main X1
Bearing - Trust (Par) X1
Oil Pump Case[Front Cover] X1
Oil Pump Gear Inner & Outer X1
Oil Pump Pressure Relief Piston X1
Oil Pump Pressure Relief Spring X1
joeapple8 is offline   Reply With Quote
