Old 05-18-2018, 01:57 PM   #1
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
FS: IS-F Front Calipers (6 pot brembos)
I am not sure if anyone could use these on here but im going to give it a shot.
2008-2014 IS-F Front Calipers. According to the dismantler I bought them from, the 08 IS-F had 84k miles on it before it died (). I had planned to make an adapter to put on my IS300, but I don't have the time right now to do so and will buy some other BBK down the line.
I believe the IS350 also shares the same spindle part number as the IS-F, which means these should bolt right up to IS350 spindles (you will also need the rotors).
You can buy the rebuild kit directly from Lexus. I believe its around 25 a side. These cost 700ish a side brand new from the factory. I recommend disassembling them, sandblasting, recoating, rebuild, and new pads as the dismantler decided not to drain all of the brake fluid out prior to shipping to me. I wiped them down when I got them, but they will still need to be recoated.
650 + shipping (includes tracking). located in northern ca. PM your zip for a quote. paypal only. not interested in trades unless you have altezza parts. these can be somewhat hard to find, and when you find them the seller usually wants an arm and a leg for them. im just looking to get what i paid for them.
jumpman2334 is offline   Reply With Quote
Old 05-18-2018, 02:03 PM   #2
afishysilvia
afishysilvia's Avatar
Trader Rating: (31)
afishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfectionafishysilvia is close to perfection
Feedback Score: 31 reviews
Bump for another Tezza owner :]
-These would be hard to adapt to any IS from what Fig performance says. Still good price for any other Lexus chassis owners here.
Dont be a pussy...Leave your name
afishysilvia is offline   Reply With Quote
Old 05-18-2018, 02:12 PM   #3
jumpman2334
thanks. i mocked it up briefly a couple of months ago and it can be done with enough time and effort. i just dont have the time to go buy the steel and mill out the adapters right now. i was mostly worried about pedal feel and wheel clearance issues.
FYI for potential s13/14 owners looking to upgrade. The calipers look very similar to the CTSV 6 pots, but im not sure if they are the exact same. it looks like ctsvbrakeswap.com and street faction both sell ctsv adapters. i would check in with them and see if these work.
Old 05-22-2018, 03:59 PM   #4
jumpman2334
bump msglgnthttt
