Old 08-04-2018, 08:04 PM   #1
Battle Cat
Battle Cat's Avatar
Battle Cat is an unknown quantity at this point
Send a message via AIM to Battle Cat
S13/s14 sr20 part out motor/suspension/etc
Everything is located in Hawthorne ca. 90250
No I don’t want to trade any parts. Cash money only. First come first serve.
Only shipping small items at buyers expense.
Not everything listed has a price. So make reasonable offers
Will up date the pricing when I can.
Engine bay
- [ ] $4500 Zenki SR20DET-
Zero miles, House of kolor magenta valve cover paint, purple weld cover, tomei oilcap,CP pistons, eagle rods with ARP rod bolts. ARP head studs, Apexi headgasket, BC springs and titanium retainers, ACL race main and rod bearings. Oem Nissan thrust bearings. Fully machined and balanced internals. 740 deatschwerks injectors(brand new), brand new tomei oil pan, nismo thermostat,Tf-works purple pulleys
- [ ] $700 S15 turbo(low miles)with hks wastegate, stock s13 turbo manifold, and greddy hotside elbow, and ss lines for coolant and oil.
- [ ] $10 Z32 fuel filter
- [ ] $150 Cusco motor mounts
- [ ] $20 Circuit sports aluminum coolant
- [ ] $800 authentic MSPORTS silvia TYPE B aero (front bumper, canards, side skirts and rear bumper )
- [ ] $40 clear front turn signals silvia
- [ ] $ s13 5 speed parts: clutch pedal( reinforced like nismo) clutch master, steel braided line to clutch slave, and clutch slave
- [ ] $115 plus core brand new steering rack
- [ ] $80 s14 passenger seat
- [ ] $ s14 seat belts
- [ ] Megan ps rack bushings
Suspension/drive train
- [ ] $800 Os giken super single clutch and flywheel
- [ ] $300 S13 sr20 transmission
- [ ] $100 6 bolt axles
- [ ] $700 Z32 front calipers with bbk adaptor and z33 rotors and ss lines Z32 rear calipers, z32 hubs with extended studs, spindles, up rights, brand new project mu shoes and ss lines Z32 2+2 ebrake cable and bracket for cables
- [ ] $250 Gt spec front and rear strut bars
- [ ] $800 Pbm 10/8 first gen coilovers
- [ ] $600 Rival auto works angle kit- s14 modded knuckles, +25mm s13 lca’s with s14 ball joints, moog outer tierods, máxima inner tie rods, modified front cross member and Drift knuckles bent style tension rods
- [ ] $200 Nismo power brace.
- [ ] $100 Pbm skid plate
- [ ] $200 S14 front and rear 5 lug hubs
Other parts
- [ ] $500 S13.4 hybrid cover painted hok
- [ ] $350 S13.4 hybrid cover un painted broken corner section
- [ ] $130 S13 Freddy intake manifold polished
- [ ] $400 S14 t28 turbo with manifold
- [ ] 3 s13 sr20 altonators
- [ ] $80 S14 sr20 starter
- [ ] $180 S13 Buddy club spec 2 cat back(missing 2 hangers) and banged up
- [ ] $320 Bnib tomei 256 drop in cams for s13 sr20
- [ ] $100 S14 front knuckles
- [ ] S13 fuel pump assembly
- [ ] $200 brand new S14 SR20 mishimoto radiator
- [ ] $280 Chase bays SR20 ps reservoir new
- [ ] $80 S13 Cusco rear strut bar
- [ ] 2 pairs of z32 rear up rights with coil over mount $80 each pair
- [ ] Zenki s14 sr20 wc ecu $120
- [ ] S15 t28 stock wastegate $20
- [ ] S13 coupe Hic window visor brand new $40
- [ ] $40 each1 sr20 And 2 ka power steering pumps
- [ ] $50 s14 sr20 water neck
- [ ] cwest s15 front bumper canards cf
- [ ] cwest s13 pop up front bumper canards cf
- [ ] blitz bov $100
- [ ] $130 brand new nismo sr/ka thermostat
Battle Cat is offline   Reply With Quote
