Old 08-20-2018, 07:59 PM   #1
dilblood
dilblood's Avatar
dilblood is an unknown quantity at this point
‘99 lexus gs300 ***caged, widebody, nonvvti 2jzgte, drift ready, one of a kind build!
Let me start of by saying this, I am in absolutely no rush at all to sell the car. This car is my pride and joy and I've dumped endless hours into this thing over the past couple years to get it to where it is now. There's also a number of parts on the car that cannot be replaced, even if money wasn't an object.
-serious inquiries only
-no joyrides
-no lowballs
-will consider reasonable offers
-or trades of equal/more value
**asking price is $29,000**
I have over $60k in receipts
Onto what's important. I purchased the shell in may 2016, most all of the mechanical work that's been done on the car was done by me, anyone that knows me/the car knows how much of a quality build this thing is. It really is a one of a kind. Absolutely no corners cut, I mean hell the a/c blows colder in this thing than my daily.
Onto the mod list:
Drivetrain/Motor:
2jzgte non-vvti longblock w/ under 50km ($3000)
r154 transmission w/ under 60km ($2100)
Driftmotion r154 transmission mount kit ($120)
Driftmotion JZ single turbo downpipe ($100)
Driftmotion v-band exhaust flange kit (40)
HKS adjustable cam gears ($400)
HKS 2jz timing belt ($200)
Custom steel braided/coated fuel line to FPR -6AN ($70)
Driftmotion fuel rail kit 14mm -6AN ($240)
ACT extreme/strip r154 clutch kit ($660)
Cube Speed short throw shifter ($180)
R154 shifter custom extended 3” ($225)
ARP head studs JZ ($160)
ARP main stud kit JZ ($140)
ARP rod bolt set JZ ($70)
ARP flywheel bolts ($40)
Driftmotion lightweight flywheel ($360)
Driftmotion oil cooler kit ($380)
NGK iridium IX spark plugs 2667 ($50)
OEM supra water pump (both halves) ($240)
OEM engine gasket kit ($440)
Dirftmotion oil line kit -4AN feed -10AN return ($180)
OEM bearings, synchros, seals for r154 ($280)
Marlin Crawler HD Bearing retainer ($100)
Marlin Crawler Chromoly Thrust Washer ($180)
Marlin Crawler Billet 1-2 Shift Fork ($100)
Driftmotion Billet 3-4 Shift Fork ($80)
Driftmotion Billet 5-R Shift Fork. ($80)
ACL race main rod thrust bearing set ($190)
R154 shifter custom extended 3” ($230)
Aeromotive AFPR kit ($260)
ID1350 flex-fuel injectors ($1400)
Dual Walbro 450lph fuel pumps w/ Squash Performance hanger ($900)
Dual relays +wiring for pumps, along with a power block ($100)
AEM 3.5 bar MAP sensor ($160)
Turbosmart boost tee ($80)
Mishimoto radiator hoses ($100)
AEM 30-6100 Supra TT series 2 EMS ($2000)
Megan Racing motor mounts ($180)
Tial MV-R 44mm wastegate ($360)
OEM oil pump ($200)
Sheepey Built T4 divided exhaust manifold w/ 44mm wastegate ($1600)
Custom intercooler piping + couplers/clamps ($800)
AEM air filter w/ Vibrant tubing ($100)
Flanged dump-tube for 44mm wastegate ($80)
Tweak’d Performance custom wiring harness ($1440)
Precision 6466 T4 divided .84 A/R v-band ($2000)
Carbon fiber spark plug cover ($140)
Tial sport Q series 50mm BOV ($260)
Napol ignition coil packs ($400)
ID USCAR to Denso adapters ($100)
Marlin Crawler VSS ($50)
Driftmotion clutch release hub kit w/ bearing ($120)
PHR billet power steering pump fitting -10AN ($50)
Mishimoto gold intercooler ($300)
Mishimoto racing thermostat ($60)
Gates serpentine belt for ATI dampener ($40)
ATI dampener ($560)
Anodized purple dress-up kit ($80)
Underdrive lightweight pulley set ($100)
Billet TRD oil fill cap ($70)
New OEM gs300 motor mount brackets ($100)
Custom steal-braided line & -6AN fittings for fuel rail ($100)
New OEM gs300 A/C pump ($300)
New OEM power steering rack & pinion ($315)
Titanium turbo blanket T4 ($80)
3” one-piece Aluminum Driveshaft for 1jz/2jz R154 with Aluminum differential adapter ($700)
Welded Rear differential with a 1/2 in plate ($200)
Dual Flex a Lite Fans ($200)
Custom 3” aluminum radiator ($320)
A/c lines and Condensor ($100)
Custom -an fitting stainless lines for the Fuel feed and fuel return ($60)
Drift motion -6AN in line Fuel filter ($20)
Custom aluminum power steering reservoir -6AN return -10AN feed ($100)
-6AN stainless steel lines for the steering rack both return and feed ($80)
New OEM power steering pump ($250)
New OEM coolant temp ECU sensor ($50)
Sheepey Built catch can w/ stainless steal lines -6an fittings ($300)
Suspension:
Powerd by max coil overs 22kg 20kg ($800)
40mm front RCA ($120)
New inner and outer tie rods ($60)
New lower ball joints ($60)
Top speed front under brace ($180)
SPC front upper control arms ($400)
Front and rear blue TRD stabilizer bar ($500)
Battle version Aluminum steering rack bushing ($60)
Battle version rear upper control arms (Track version) ($600)
Battle version rear toe arms ($200)
Battle version rear traction arm ($200)
Battle version solid differential bushings ($120)
Interior:
Bride MO seat rails ($500)
Bride Gradation ZETA III bucket seats ($2400)
Takata drift III 4-point snap-on 3” harnesses ($600)
Joe’s fire extinguisher mount w/ extinguisher ($300)
Marlin Crawler Shift Knob ($60)
Full custom 6-point weld-in cage ($2500)
NRG short hub ($80)
NRG quick release ($80)
Momo 350mm deep corn leather ($140)
ASD hydraulic e brake & custom lines ($320)
Joe's Racing rear view mirror ($60)
1100watt CRUNCH amp ($60)
1000watt Kicker 12in sub ($60)
Battery relocated to trunk ($40)
AEM x-series UEGO gauges ($700)
Exterior:
Authentic BN Sports full body kit ($2400)
OEM Toyota window visors ($200)
OEM Toyota chrome door handles ($250)
Depo LED taillights ($300)
Serial nine rear quarter panels ($500)
Custom hibino style fenders ($350)
Toyota aristo Front grille ($100)
Amethyst pearl with gold flake ($2500)
Wheels/Tires:
Avante Garde F220 brushed gold faces w/ chrome lips ($5200)
Front- 19x10 -14 offset
Rear- 19x12 -39 offset
Front- Hankook evo2 k120 235/35/19 ($400)
Rear-Hankook evo2 k120 275/30/19 ($480)
Muteki open-end lugs ($80)
Brakes: ($1500)
Front- (under 500 miles)
Stoptech rotors
Rear- (under 500 miles)
Wilwood 4 piston BBK
Wilwood 324mm rotors
Wilwood brake pads
Wilwood stainless steel lines
VIN: JT8BD68S5X0054621
dilblood is offline   Reply With Quote
