Old 08-30-2018, 11:52 AM   #1
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
Garage Sale of 240sx Parts (DCC , Power Steering Stuff, KA/SR Starter, Bushing Kit,
Contact can be made via :
Private Message
I’m Located In Orlando FL. Each item will be cleaned the best I can before being shipped.
Paypal Verified. Shipping price is not included, you pay for it.
Cash pick up is available for locals.
Please be mindful of the set price as it reflects the condition.
Please include paypal-fee in payment or send as gift.
***PLEASE : Do not ask if anything else available. If I don't have it listed, I don't have it or it sold ***
All used items have been tested : working unless stated otherwise. Sold as is. No Returns.
List :
List :
Power Steering Stuff:
KA24DE Power Steering Pump SOLD
2 KA24DE Power Steering Pulleys $15 each
KA power steering adjusting bracket $25
Two KA24DE power steering pump brackets $20 each
KA24DE Power Steering bracket (HOLDS PUMP) $65
2 KA/SR Power Steering Small Banjo bolts with washers $15 each
1 KA/SR Power Steering Main Banjo $20
240sx Stuff
NEW Energy Suspension Polyurethane Bushing Kit S14 240sx - $160
-Never used still in original box has everything listed below. Black polyurethane bushings (the best).
Hyper-Flex System Includes (does not include sub frame or rear sway bar includes everything listed):
Front And Rear Control Arm Bushings
Front Sway Bar Frame Bushings
Front strut bar bushing set,
Ti-rod boot set
S14 digital climate control - $140
OEM KA24DE STARTER (TESTED - WORKS PERFECT ) SOLD
OEM S13 SR20DET STARTER SOLD
s13/s14 KA24DE AC Mounting bracket (with pulley) $65
S14/S13 Transmission mount (KA or Sr20det compatible) $40
Two front s14 brake lines (No leaks) $15
Like New S14 Axxis Ultimate brake pads $40
95 Nissan 240Sx Cruise Control Actuator with cable $30
KA/ SR(S14 or S13) throwout bearing retainer/sleeve with good throw-out bearing on it $30
EGRC-bpt Valve (part of egr set) (part of #47 ) $20
S14 EGR with pipe $25
KA24de 02 Sensors $25
SR20DET COIL PACKS (Few are working, could all be working, cant remember, use as replacements) - $20
KA Auto transmission Sandwich plate $40
KA/SR Transmission Shifter Plate housing only $60
REDTOP #62 ECU (won't turn the fuel pump on, can be corrected with a solder fix)$40
s14 KA24DE MAF ( the tabs are broken on it) $20
GATES K040345 $10
Other Other Stuff:
Large fan 16 inches $15
Smaller MAF adapter plate $15
Taller MAF adapter plate with sensor port $25
Large Aluminum pip 3.50 diameter (flange on it has a little cut in it) $20
Random Intake pipe (plastic) $15
Random Intake pipe (plastic) #10
s14 OEM radio amp $40
95 s14 (kA) heater hose valve $25
S14 gas door ( will need to be painted) $15
s14 Auto Shifter Bezel $15
Other Misc Things
S14 Cruise Control Switch $18
S14 Dash Light Dimmer Switch $18
95-98 Nissan S14 Auto transmission Computer (31036 70f00) $60
Unknown Plugs
KA JECS Resistor (a15-000g000 ) $15
44. 1995 Nissan 240Sx Cruise Control Pump Servo Module $25
Other Stuff:
20+ ft of extremely strong hood lock cable $40
Turbonetic Delgate Mark 2 Wastegate $150
- With a brand new 9 PSI spring, screw, and nut still in the bags.
Subaru WRX BOV Authentic Turbo XS TYPE H-RFL BLOW OFF VALVE $120
Smaller Unknown BOV $40
Vortech Engineering Fuel Pressure Regulator 10:1 $140
Orange Oil Relocation kit as is $40
Exhaust Wrap $15
2 Blue 3" Couplers ( have some of the rubber gashed but no holes in the coupler itself) $10
Assortment of used heavy duty medium clamps for intercooler couplers (12) $10
3" Strong T Clamps - 3 of them $15
A collection of Fittings for -10AN and other size I don't know (used these on oil cooler and relocation kits) $40 for all 7
0.25" Wheel Spacers $15
Oil Cooler Bracket $20
Images:
Dorifto Machine is offline   Reply With Quote
Old 09-03-2018, 11:02 PM   #2
Dorifto Machine
Happy Labor Day Bump!
Old 09-04-2018, 04:20 PM   #3
Dorifto Machine
SR Starter SOLD. I do also have a KA starter in working/tested condition!
Old 09-06-2018, 11:34 AM   #4
Dorifto Machine
Let me know what you need...
Old 09-08-2018, 07:29 PM   #5
Dorifto Machine
Ton of stuff available let me know what you need !
Old 09-10-2018, 12:47 PM   #6
Dorifto Machine
new week bump
Old 09-12-2018, 10:55 AM   #7
Dorifto Machine
to the top
Old 09-15-2018, 11:20 AM   #8
Dorifto Machine
Old 09-15-2018, 02:39 PM   #9
tootall4la
tootall4la's Avatar
tootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to alltootall4la is a name known to all
DCC what else is needed?
tootall4la is offline   Reply With Quote
Old 09-15-2018, 02:51 PM   #10
Dorifto Machine
It just comes with the unit
There is a write up on here for the rest if you want to research (how to set up the plugs etc..)
Old 09-16-2018, 10:37 AM   #11
Dorifto Machine
All PMS replied!
Old 09-17-2018, 02:44 PM   #12
Dorifto Machine
Let me know what you need, whatever is listed is still available.
Old 09-19-2018, 01:23 PM   #13
Dorifto Machine
To the top Wed
Old 09-21-2018, 11:36 AM   #14
Dorifto Machine
Let me know if you need something, Happy Friday!
Old 09-22-2018, 12:15 PM   #15
Dorifto Machine
Happy weekend, items listed are here , let me know what you need!
Old 09-25-2018, 03:43 PM   #16
Dorifto Machine
Listed items available, Thanks!
Old 09-26-2018, 11:03 AM   #17
Dorifto Machine
Happy wed,let me know what you need !
Old 09-27-2018, 09:45 AM   #18
Dorifto Machine
Lets get you some goodies
Old 09-29-2018, 04:17 PM   #19
Dorifto Machine
If listed its still available, Thanks!
Old 10-03-2018, 10:26 AM   #20
Dorifto Machine
Enjoy your fall week bump!
Old 10-04-2018, 11:44 AM   #21
Dorifto Machine
Happy thursday
Old 10-08-2018, 10:04 AM   #22
Dorifto Machine
Old 10-13-2018, 09:58 AM   #23
Dorifto Machine
Happy weekend to all bump!
Old 10-17-2018, 02:03 PM   #24
Dorifto Machine
If it’s listed it’s available !
Old 10-20-2018, 05:33 AM   #25
Dorifto Machine
Happy oct bumpity
Old 10-22-2018, 09:27 AM   #26
Dorifto Machine
Happy 1 week till Halloween bump!
Old 10-29-2018, 04:02 PM   #27
Dorifto Machine
Items listed are available.
Old 10-31-2018, 12:39 PM   #28
Dorifto Machine
Grateful to be alive bump, stay awesome friends!
Old 11-02-2018, 01:07 PM   #29
Dorifto Machine
Happy Friday to all bump! Anything listed is available
Old 11-04-2018, 12:44 PM   #30
Dorifto Machine
Bumpity bump!
ka24de parts, sr20 starter
