Old 09-24-2018, 07:19 PM   #1
smoketherear
smoketherear is an unknown quantity at this point
S14 sr20det 1500 rpm cut
What's up guys, I've dug through decades worth of old posts hoping that someone has encountered this problem before with a resolution.
All my Nissan gurus any input would be greatly appreciated. Things already checked off and changed:
Knock sensor
Ecu coolant sensor
Maf ( tested with a known working one)
Ecu same as maf tested with a known good working one
O2 sensor swapped with a new one
Fueling on the car it has a new pump
Oem injectors where cleaned and tested
No codes present via Nissan consult.
Swapped the trigger disc with a known good one out of my car .
https://youtu.be/GsDLvj4Cgow
Sent from my Pixel 2 XL using Tapatalk
smoketherear is offline   Reply With Quote
Old 09-25-2018, 06:47 AM   #2
Kingtal0n
Kingtal0n's Avatar
Its the maf. Its always the maf (its never the maf) lol
1500rpm cut = no maf to ecu
Old 09-25-2018, 10:26 AM   #3
zenkicpe
zenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud ofzenkicpe has much to be proud of
MAF wiring? Boost leak and bad MAF wiring?
zenkicpe is offline   Reply With Quote
Old 09-25-2018, 11:31 AM   #4
smoketherear
At the pigtail the maf is getting the sign ,power and ground
