Old 11-05-2004, 10:58 PM   #1
sr240mike
sr240mike is making a name for him/her selfsr240mike is making a name for him/her selfsr240mike is making a name for him/her self
SR Sr AIV removal, question for ecu tuners. Quite technical.
Ok so with 300zx's when you install an aftermarket ecu such as JWT the AIV's are deleted in the code somehow and smog is unnaffected. Do they lean out the idle portions of the fuel maps or is there actual code to remove the AIV? After some searching on www.twinturbo.net removing the aiv's without an ecu upgrade it is common for the car to stall while decelerating as well as running fairly rich around idle. That sounds like a similar problem many sr swapped cars have. So if anyone has any insight to this please let me know so I can alter the ecu to adjust for aiv removal. Thanks in advance.
TWO IN THE COOT, ONE IN THE POOT
sr240mike is offline   Reply With Quote
Old 11-05-2004, 11:24 PM   #2
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
yes, on some cars JWT does exactly as you said. They lean out the idle to reduce emissions. This is why some newer cars didn't have an AIV, when some older ones did. The engineers just leaned out the idle to be able to do away with the AIV/PAIRC system.
to do it yourself, you'd have to get a new writable eprom and an emulator and whatnot.
RBS14 is offline   Reply With Quote
Old 11-06-2004, 01:37 AM   #3
sr240mike
No emulators available yet, but I have a daughterboard and eprom programmer. I was just looking the the stock maps and jwt's of a 300zx tt and dont see any differences in the closed loop maps. Yeah 93 and newer 300zx's didnt have the aiv's, do blacktop sr20's have them?
Old 11-07-2004, 01:35 PM   #4
RBS14
RBS14's Avatar
what do you mean, no emulators available yet, there are a few different ones. Maybe it couldn't emulate the eproms that SR's use? I know people have used them on KA eproms. There was a link on some ecu tuning forum I used to visit. Problem with SR's is that they have dual eproms or something like that, which is incredibly difficult to figure out. I'm not sure if blacktop SR's have AIV's or not.
Old 11-08-2004, 08:29 PM   #5
sr240mike
Sr's daughterboards are 16 bit so you would need 2 emulators but some people are working on it.
