Old 11-20-2018, 12:34 AM   #1
celbii
celbii is an unknown quantity at this point
Nice 1988 Rx7 T2 Vert
***FULL HQ PICTURES HERE***
https://imgur.com/a/5RXg9jQ
I am sadly selling off my car collection due to a lack of time and energy to maintain it. I have other priorities to address at the moment so I am looking to consolidate down into just one newer daily driver. I will also have a built 469rwhp FD and a showcar sr20 180sx clone for sale in the near future. I am not interested in any trades whatsoever. No I will not do payments.
Clean title in hand. Serious buyers only please. There is a lot of time and money invested into this RX-7 and it has been taken care of extremely well. I will remove personal effects and stickers of course pending sale, unless next owner wants them left on, its an aesthetic preference after all.
This is a modified original Naturally aspirated convertible motor, with a with a factory T2 turbocharger added on. Mileage is original at 69,6xx(This will go up as I am currently dailying it) and the RX-7 is still utilizing the NA transmission and open differential from the factory. I have just recently replaced and upgraded the clutch to an Exedy Stage 1 in July earlier this year. So its pretty much new. The modification list is fairly expansive and most likely may have missed a thing or two. However I will list the general modifications I can remember and the ballpark timeframe.
Asking $8,500. Any reasonable offer will be entertained but do keep in mind this isn’t your average falling apart RX-7. Test drives for serious buyers with proof of funds. Located in Oklahoma city, will ship.
Exterior
* Turbo II hood
* 89 Mazda MX-6 GT front splitter
* Black Tie Motors Feed replica side skirts
* LED bulbs in semi-sealed glass headlamps
* Mazda OEM duckbill spoiler
* S5 Convertible Tail Lamps
* All exterior bulbs have been replaced with new Sylvania amber or high-output equivalent bright bulbs
* New Haartz Stayfast Canvas Convertible Top w/ new rainrails and drains
* New OEM Mazda Convertible Top Seals
* Racing Hart CP5 17x7 +40 offset wheels
* Project Mu Lug Nuts
* New Yokohama Avid Envigor 225/45/17 tires
Suspension and Brakes
* KYB Shocks front and rear
* Racing Beat Springs
* RX-7 Turbo 2 4-piston caliper conversion
* Powersport slotted rotors w/ ceramic pads front and rear
* New OEM inner and outer tie rods and alignment done replaced this year
* End links front and rear replaced this last year
* Motor mounts and transmission mounts replaced 2016
* No there isn't any rust! Its a garage queen
Engine and Cooling (runs at 9.5 psi)
* Rtek 2.1 ECU w/ Tungsten T3 full-color Palm Pilot and Cradle
* Racing Beat Rev TII Exhaust
* Banzai Racing emissions block off kit
* 130 AMP hi output alternator
* Banzai Racing alternator bracket tensioner
* Banzai Racing dual alternator pulley
* New starter with modified 2kW starter motor
* Optima Yellow top 2017
* Modified S4 Turbo 2 Lower intake manifold port matched for 6 port motor
* S4 Turbo 2 upper intake manifold
* S4 modified throttle body with secondary plates and thermowax removed
* Apexi Twin Chamber blow off Valve for FC RX-7 (pretty rare)
* Manual boost controller (set at 9.5 psi - for reliability, and car isn't tuned. Its only running the default 550/720 setup on the Rtek 2.1)
* Full silicone vacuum hoses
* Engine grounds redone
* Oil catch can installed
* New RC 550cc Injectors Primary (low impedance) 2018
* New Nippon Denso 720cc Injectors Secondary (low impedance) 2018
* New fuel feed and return fuel hoses 2018
* New OEM Mazda fuel filter 2018
* New Walbro 190lph fuel pump
* Racing Beat oil cap
* New OEM Mazda fuel pressure regulator 2016
* New OEM Mazda water temp sensor 2016
* Banzai Racing fuel pulsation dampener delete
* All new Gates belts replaced earlier this year 2018
* New AC Delco waterpump 2017
* New waterpump housing gasket 2017
* New thermostat 160F Motorad
* New OEM Mazda Upper Radiator Cap 2017
* Koyo polished radiator
* Koyo uprated radiator cap
* FF Dynamics 3600 CFM electric fan with controller and custom aluminum shroud
* Silicone Radiator hoses with Mishimoto temperature sender adapter for Autometer water temp gauge
* 7-inch aux fans for AC condenser with separate Mishimoto fan controller
* New NGK OEM Ignition Wires 2018
* NEW NGK Spark Plugs leading and trailing 2018
* Engine Oil Changed using Eneos 5W-30 full ester based synthetic
* Transmission fluid flushed and changed using Eneos 75W-90 full ester based synthetic 2016
* Differential fluid flushed and changed using Eneos 75w-90 full ester based synthetic 2016
* Coolant flushed and changed using all Zerex Asian Pink coolant 2017
*New Mazda clutch master cylinder 2018
*New Mazda clutch slave cylinder 2018
*New Atkins rotary stainless steel braided clutch line 2018
Interior
* Dash is crack free, demister vents are perfect
* All dash vent plastics have been replaced with new Mazda OEM 2016
* Smoke velour dashmat installed to add more clean look to interior 2016
* Clutch pedal rubber replaced with new OEM Mazda 2016
* Lloyd custom ultimat plush floor mats (charcoal) 2016
* S5 rubber surround 2016
* Android double din with DVD player, navigation, bluetooth, etc, 2016
* Shifter fully rebuilt using Mazdatrix kit and all bushings 2016
* Custom Redline Goods dual color and stitched black/grey shift boot and matching ebrake boot 2016
* FEED Combination heavyweight shift knob 2016
* Mazda Retro cigarette lighter
* Fold-down hideaway cupholder
* Kenwood Performance Line speakers all around 2016
* Kenwood micro amplifier
* Kenwood mini subwoofer mounted behind drivers seat
* Autometer Sport-Comp Boot and Water Temp half-sweep analogue gauges
* Viper 5305V alarm installed (Only utilizing keyless entry and shock perimeter features - all other features like keyless start would need to be wired if you want to use them)
* Seats reupholstered from Racing Beat 2018 super clean interior, like new and car gets a lot of attention for being so nice
* Refurbished driver and passenger window switches from Rotary 13betc 2016
celbii is offline   Reply With Quote
Old 11-20-2018, 12:52 AM   #2
dizzariot
dizzariot's Avatar
Trader Rating: (47)
dizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfectiondizzariot is close to perfection
Feedback Score: 47 reviews
FUCK this is cool. Can't wait to see the Type X clone...
The mark of a true sucka: 'RARE JDM' & 'OLD LOGO NISMO'
dizzariot is offline   Reply With Quote
Old 11-20-2018, 09:54 AM   #3
celbii
Yeah she is pretty cool This is my 4th FC I've owned haha. I posted up the 180 also, check my other thread
Old 12-09-2018, 11:51 AM   #4
celbii
Price drop $7900
