Old 01-03-2019, 01:20 PM   #1
Bkiesler924
Bkiesler924 is an unknown quantity at this point
s13 Idle problems?!?!!!
Hi I'm new to this site and needed some help I just recently got rid of the hatch I owned for 5 years to get a vert. It's alot nicer then my hatch was the biggest problem I've found is the high idle, when I got it i didnt think anything of it searched and found how to adjust the idle warmed it up unplugged the TPS. I couldn't drive it around like the post said to do because its idling at about 1800rpm. I turned the idle screw down and it got to about 1300rpm and the screw stopped it wouldnt go any further but still needed to go down, it has about a 400rpm flutter at points that will drop it to about 15-1400rpm. I kept thinking it was a vacuum leak so I started looking at vacuum lines all the ones I can see are plugged with a screw or stopper and dont seem to be leaking. I dont get what's wrong so I thought yall might be able to point me in the right direction. I tried searching it and it always brought me back to the same article I already read about how to adjust it or similar posts. I've got most of the other problems with the car fixed but this one has stumped me so if anyone could help it would be very appreciated.
Bkiesler924 is offline   Reply With Quote
Old 01-03-2019, 03:08 PM   #2
Kingtal0n
Kingtal0n's Avatar
air leak.
Idle is controlled mostly by air, leaking into the engine (somewhere).
Do a pressure test. You have leaks.
Old 01-03-2019, 03:45 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Originally Posted by Bkiesler924 View Post
I kept thinking it was a vacuum leak so I started looking at vacuum lines all the ones I can see are plugged with a screw or stopper and dont seem to be leaking. .
wait so there are vacuum lines that just have screws blocking them? sounds like stuff was removed. You may need to investigate WHAT was removed and why?
also I agree that it sounds like you have a vacuum leak. Personally I prefer to use a smoke tester, if you have a friend that vapes, those work well too. you can always use carb spray to test with the engine running too.
Old 01-05-2019, 10:42 AM   #4
Bkiesler924
s13
That's what I've been trying to do I was gonna do it with starting fluid (mainly because it's the way I know how to check for leaks) I just havent got a dry day to be able to do it. I did start a good joke with it last night I went and got a few turbo goodies for it, so I started jokingly saying what's better to fix a vacuum leak or a idle problem then a turbo hahaha. Thank yall for your help I'm searching for a vacuum diagram now to see what's been plugged and what's not plugged in. Your help is very much appreciated.
240sx, idle problems, ka24de
