Old 02-03-2019, 10:01 AM   #1
oscarsx
oscarsx's Avatar
oscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-knownoscarsx is making his/her stupidity well-known
2JZ > S14 swap parts (Harness, Driveshaft, Xmember, etc)
Parting out a few things from my S14 2JZ swapped chassis.
1. Wiring Specialties P&P 2JZ vvti > S14 (AEM INFINITY 6) $1050 shipped
Harness is for the following:
- s14 2jz vvti AEM Infinity 6 p&p
- R154 trans
- ID injector style plugs
- maf delete
- dbw delete (using driftmotion dbw delete kit)
- o2 delete
- vsv delete
- removed map sensor and replaced with AEM MAP sensor plug.
+ fuel pressure sensor plug added directly to infinity
+ oil pressure sensor plug added directly to infinity
+ 4.2 lsu plug sensor added directly to infinity
+ aem boost solenoid plug added directly to infinity
2. SR20 Koyo & Flow radiator. $220 shipped
- 0 leaks, had absolutely no overheating problems running this with Flexalite 420 fans.
3. Xcessive S Chassis to Toyota Manual Transmission Cross Member $60 shipped
- Works as designed.
4. CXRacing Aluminum Radiator Water Hard Pipe Kit $60 shipped
- 1/8 npt for coolant temp sensor
5. R154/240sx 1pc Steel Driveshaft $240 shipped
- works as designed
6. S14 Sikky Swaybar $240 shipped
IG: @ozc2jz
oscarsx is offline   Reply With Quote
