Old 03-13-2002, 07:18 PM   #1
Natesnosrocket
Natesnosrocket is an unknown quantity at this point
Im buying a Sr20 t28 turbo and intercooler from a guy and i was wondering if anyone has ever put that turbo and intercooler on a 91 Dohc ka. I need help please
thisismysigniture
Natesnosrocket is offline   Reply With Quote
Old 03-14-2002, 09:37 PM   #2
Natesnosrocket
Cmon someone must know or have answers
Please
thisismysigniture
Old 03-14-2002, 09:41 PM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
*shrugs* Sorry... not me....
Do a search on the web. A site like: <a href="www.altavista.com" target='_blank'>www.altavista.com</a> should be able to pull something up. Search for KA Turbo...
Good luck.
S13Grl is offline   Reply With Quote
Old 03-15-2002, 05:06 AM   #4
ca18guy
ca18guy's Avatar
ca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfectionca18guy is close to perfection
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Natesnosrocket @ Mar. 13 2002,2:18)</td></tr><tr><td id="QUOTE">Im buying a Sr20 t28 turbo and intercooler from a guy and i was wondering if anyone has ever put that turbo and intercooler on a 91 Dohc ka. I need help please</td></tr></table><span id='postcolor'>
daperformance sells part that you can piece together to make the T28 fit. You'll need downpipe, manifold, oil line etc. &nbsp;What I want to know is why you wated your money on a T28 and (probably stock) intercooler &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/eh.gif" border="0" valign="absmiddle" alt=':eh:'>
ca18guy is offline   Reply With Quote
Old 03-15-2002, 10:41 AM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
If they guy wants low boost, and fairly quick spool up, then the T28 is a great choice.
sykikchimp is offline   Reply With Quote
Old 03-15-2002, 05:55 PM   #6
Natesnosrocket
Auctually the quick spool up is true and so is the low boost seeing im currently installing a 4 stage nos fogger system starting at 100hp shot and going up in 50hp increments
thisismysigniture
Old 03-15-2002, 11:00 PM   #7
Datsun_Man
Datsun_Man is an unknown quantity at this point
Better be running a strong bottom end. And if you are gonna run NOS then I would get a larger turbo b/c the added exhaust from spraying can spool up a larger say T3/04 or TD06 as fast as a normal T28 can spool. But if you are gonna run low boost then the T28 is good because of its awesome efficiency at less than 14 psi levels.
Datsun_Man is offline   Reply With Quote
Old 03-16-2002, 04:05 AM   #8
junia
junia is an unknown quantity at this point
Send a message via Yahoo to junia
You shouldn't have any problems with spooling any one of the turbos mentioned earlier because I've never had a problem with turbo lag running TD06-20G on a Stock SR20DET (with only cam upgrade). I'm pretty sure the KA would probably spool up faster, actually about 99.99999999% positive that they spool up faster in the KA. &nbsp;The Ball bearing T28 is a good choice if you want somewhere around the 300HP range with a nice flat torque curve.
1990 Nissan 240sx hatchback, 1991 Nissan Silvia K's PS13, 1978 Toyota Corolla KE-30
junia is offline   Reply With Quote
