Old 11-12-2004, 02:22 PM   #1
The ROMAN
The ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to beholdThe ROMAN is a splendid one to behold
decreasing camber
This is kinda wierd. When I first got my Tein HEs I set the camber plates at roughly 1 degree, about six lines up from 0. Eventually I set them full, and experiencing no tire wear problems, I left em that way. I had a pretty decent amount of camber, but now it seems to be decreasing on one side, even though the camber plates are still at full. The passenger side (eyeballing it) seems to have 2.5-3 degrees, while the driver side seems to be at 0.5-1.
Any ideas what could be causing this?
Since there's no eccentic bolt or anything in the front, would an alignment really help me at all?
P.S. Ride height on all four corners is within 3/4" of each other .
The ROMAN is offline   Reply With Quote
Old 11-12-2004, 03:10 PM   #2
Salty_X
Salty_X is an unknown quantity at this point
Maybe the lower bracket bolts are loose? The top bolt hole on it is slotted so maybe it's just working it's way outward.
Salty_X is offline   Reply With Quote
Old 11-12-2004, 04:11 PM   #3
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
that's my vote
RBS14 is offline   Reply With Quote
Old 11-12-2004, 04:42 PM   #4
The ROMAN
You mean were it bolts to the spindle? I'll check that out thanks.
Old 11-12-2004, 05:41 PM   #5
mellojoe
mellojoe is an unknown quantity at this point
Also, springs have a tendancy to settle. If you adjust the camber IMMEDIATLY after installation, you need to have it re-aligned about 6 months down the road. THEN you should be set. My springs did the same thing. Started at a nice -1.2deg and end up at -2deg up front.
mellojoe is offline   Reply With Quote
Old 11-12-2004, 07:14 PM   #6
XxJaPxOxNeEs23xX
XxJaPxOxNeEs23xX's Avatar
XxJaPxOxNeEs23xX is making a name for him/her selfXxJaPxOxNeEs23xX is making a name for him/her self
Send a message via AIM to XxJaPxOxNeEs23xX
i used the alignment machine to do my alignment. i ddnt trust the lines on the camber plate. because ur care will never be equal from left ot right with the camber plates. it should be close but not exactly the same. also u have to know that u can change ur camber without the camber plates. you know how people get their car aligned without camber plates right, with stock setting, u just have to try to make both sides equal with the stock settings too.
XxJaPxOxNeEs23xX is offline   Reply With Quote
Old 11-13-2004, 04:05 PM   #7
The ROMAN
Nice, I fixed that top bolt. Now it's even, and I can get retarded amounts of camber once again, all without an alignment. Awesome.
