Old 11-12-2004, 09:49 PM   #1
carkid0007
carkid0007 can only hope to improve
E-brake adjusting
How can you adjust the e-brake on the s-13 ?? to make it tighter
carkid0007 is offline   Reply With Quote
Old 11-12-2004, 11:10 PM   #2
rainier
rainier's Avatar
rainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud ofrainier has much to be proud of
Send a message via AIM to rainier
pull it up until u see the slot to stick a long socket in. i think its a 10mm but yeah. just tighten?
rainier is offline   Reply With Quote
Old 11-13-2004, 01:47 AM   #3
ALTRNTV
^^ what he said.... haha
ALTRNTV is offline   Reply With Quote
Old 11-13-2004, 02:39 PM   #4
carkid0007
when I pull the e-brake all the way up it just seems like the car might roll away or something....
Old 11-13-2004, 02:59 PM   #5
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Before you go thru all the hassle of adjusting your e-brake, pull your rear tires & see how much pad you have left on your rear brakes. Why bother adjusting your e-brakes if you have NO pad left??
If your pads are shot & they are worn down to nothing, then replace your pads. Once you replace your pads THEN adjust your e-brake. According to the FSM, you're only supposed to pull the e-brake up SEVEN (7) clicks - zero is when the e-brake completely released & down. Click up seven clicks from there. Once you hear the seventh click, stop pulling. Pull out your deep dish socket wrench then tighten the cable from there. The adjusting hole should barely be visible at that point.
Anyhow, hope this helps...good luck...
ID
idlafie is offline   Reply With Quote
Old 11-14-2004, 12:45 AM   #6
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
yeah what these peeps said!!
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 11-14-2004, 11:56 AM   #7
carkid0007
Thanks for the help !!
