R Chassis Technical discussion related to the R Chassis such as the R31, R32, R33, R34, and R35. |
![]() Hey guys I have an rb25det swapped 240sx which i received recently.
I changed the following things recently spark plugs from brp6es to brp7es Coil packs from Yellow jackets to splitfires I noticed it was backfiring on idle and when I revved it, it seemed to be revving rough or have some sort of lag. I gapped the brp7es to .28 and the backfiring at idle stopped. However, the rough idling and the rough shaking still stays, any ideas on what it could be ? Thanks I'm relatively new to the S chasis and the RB, any and all help would be appreciated. |
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
If it already had Yellow Jacket's in it then someone's encountered this issue before and tried to fix it.
When you swapped the plugs, what did the old ones look like? Black? White? Or all different? Check the grounds for the coilpack harness - not just the connection, but the wire in the terminal might be cracked. Better yet, run fresh grounds from the coilpacks, even temporarily to check if that's the issue. After that, throw a fresh fuel filter at it and double check the voltage at the fuel pump
https://www.instagram.com/unclebensriceballs/ |
rb25det |
