Old 09-25-2019, 08:42 AM   #1
ponch1488
ponch1488 is an unknown quantity at this point
1993 Toyota cresta tourer V 1jzgte
1993 Toyota cresta tourer V (1jzgte ) located in Las V[IMG][/IMG]egas. Car is titled and registered in my name(Nevada).
Originally auto, was converted to manual (r154) by myself. Transmission is fully built. Build done by driftmotion (almost 2k for build less than 500 miles on trans). Trans was originally out of a jdm mk3 so trans extension, mounts, shifter grommets ect were all purchased through driftmotion. A 1 piece aluminum driveshaft was made by Dan's driveline here in Las Vegas. Cluthchmaster 6 puck clutch and light weight steel flywheel were intalled at the time of swap. Car is in good overall shape and shows 156km on the clock (little over 96k miles). Runs good and pulls hard. Invested over $14,000.
-Interior
Some fading is present in the front pillars and driver seat shows some wear. New shift and e-brake boot. Interior is complete and looks good.
-Exterior
Paint shows some fade and minor rock chips-dings but, is in good shape. Body is straight and no rust.
-Mechanical
Mechanically the car has some minor flaws. Power steering pump bearings make a slight grinding noise when car reaches running temp (new pump will be needed in the near future) . Slight hesitation when car is cold. This issue is gone when the car warms up(possible vacuum line leak). Wiper blades and hood-struts need replacing. Tires are starting to crack. Motor put down 165psi across the board on a recent compression test (pulls hard with stock twins)Built r154 transmission only 500 miles shifts smooth. New valve cover gasket, spark plugs and coil pack connectors.
Al 7252087258
ponch1488 is offline   Reply With Quote
