Old 01-17-2020, 06:37 PM   #1
jtmny1999
jtmny1999 is an unknown quantity at this point
*****Help*** RB25det water inlet flange
Hi Guys,
its been a while since I posted but I'm getting around to get my Z back up. I need to see if anyone knows where I can find this Water inlet flange that is pressed in on the intake manifold. I can't find the stock part number or replacement only some from the UK that are weld in type. I just need the stock one or a part number for any other car that is interchangeable. Any help is appreciated, photo for reference below. Thanks
jtmny1999 is offline   Reply With Quote
Old 01-19-2020, 09:05 PM   #2
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Generally that is only sold with a complete intake manifold. I cannot recall ever seeing one sold individually. Granted I could be wrong, I wonder if you could use one off a KA intake manifold. I saw a few for sale in the marketplace here on Zilvia yesterday. Getting it out could be tricky with out marring it up, or crushing it. Good luck post whatever you end up doing.
Old 01-21-2020, 08:35 AM   #3
jedi03
maybe measure OD and get a pipe and press it in? or get the weld in option...
Old 01-21-2020, 09:00 AM   #4
S14rebuild
Weld on a new pipe..simple
