Old 01-19-2020, 05:25 AM   #1
zachvirus
zachvirus is an unknown quantity at this point
Built SR20 complete drop in
Location is Columbia, SC
$4,500 OBRO
I have a built s13 sr20det redtop.
It was assembled in 2017 and has less than 5k on it, as I barely have driven it. I have machining paperwork. Car made 387whp on 13psi. Built for 25psi. Never got a chance to turn it up due to failing CAS at the time.
I most definitely will forget something but here we go.
S13 SR20DET REDTOP
Brian Crower 272 cams
Brian Crower Titanium Valve Springs and Retainers
Tomei Rocker Arm Stopper
S13.4 Hybrid Valve cover with 10AN fitting
Mazworx Valve Cover Dress up kit
VK56 Smart Coils
10AN Oil catch can setup
FReddy Intake Manifold
OEM Throttle Body
GKTech S14 Eccentric TB Pulley
Ebay Top Feed Fuel Rail with 8AN unions
FIC 1300cc Injectors
Intake/TB Thermal Spacer
Borg Warner S256RS T3 .63ar
Black TurboGuard Compressor Cover
Heat Blanket
4AN Oil Feed setup
12AN Turbo Oil Return setup
XSPower T3 Twin Scroll Turbo Manfiold
Multi layer exhaust gaskets everywhere
Tial 44mm EWG 13lbs spring(all springs included) and EWG tube
Modified CX Racing Downpipe
Hallman Pro RX Manual Boost Controller(with both springs)
Tial Q BOV (all springs included)
CP Pistons 8.5.1 86.5mm
Eagle Rods
Full ARP stud kit (mains, headgasket, etc)
ACL Thrust Washer
ACL Main/Rod Bearing set
Tomei 87mm Metal Headgasket
Brand New Chain/Tensioner setup
Aluminum Radiator
Custom 20AN Upper/Lower Radiator Setup with thermostatic sensor bung
14" Hayden Fan
Lightweight Pulley setup
Nissan Quest Alternator
Tomei Oil Filter Adapter Plate
Circuit Sport Oil Filter Relocation kit
S13 SR Transmission
Clutch Master cylinder to Slave Cylinder hardware
ISR Short Throw Shifter
Z1 Steel Driveshaft
Competition Stage 3 Clutch Kit
Nismo Lightweight Flywheel
Custom HMIC piping setup
All couplers and T-Bolt Clamps
Nismo Motor Mounts
Peak Performance Trans Mount
N62 billet blow thru MAF
Custom wire harness tuck
#62 Redtop ECU tuned by RS Enthalpy
Tuned for E85
Almost all parts have the same mileage as the motor or less.
Parts to be included but not pictured:
AGP .75ar Twin Scroll turbine housing with V-Band exhaust
Tial QR BOV hat
Spare nismo flywheel
OEM S13 SR intake manifold
Spare OEM Crank Pulley
Circuit Sport Side Feed fuel rail (GOLD)
Solid Motor Mounts
OEM S13 SR cams and valve springs/retainers
Handful of V-Band flanges and clamps
Handful of T-bolt clamps
Some leftover 20AN and 10AN hoses
Misc SR sensors(CAS Module, TPS, etc)
Purple silicone radiator hoses(Upper cut for fan switch adapter)
Videos of Motor running before being removed.
https://youtu.be/3pN__krkHQI
Car on Dyno with motor. Can include exhaust if requested.
https://youtu.be/eTqYuLwtKNc
Obviously this is a PICK UP preferred. WILL NOT SHIP. Will deliver for a fee per distance.
Please keep your negative or ignorant comments to yourself. Its distasteful and pointless. But if you feel the need to get yourself off.
https://www.pornhub.com/view_video.p...h5d615a8f33a7e
Last edited by zachvirus; 01-27-2020 at 02:44 PM.. Reason: Addition info and pictures of motor removed
zachvirus is offline   Reply With Quote
