Old 02-03-2020, 11:07 PM   #1
Liam pink
Liam pink is an unknown quantity at this point
How can I put my windows up (s14)
Yes sounds dumb I know. but i bought a drift car (s14 Silvia) and the drivers window won't go up for a couple reasons. The whole door panel has been replaced with a peice of sheet metal with no switch on it and probably no wires or anything running to the motor. And also I can't pull it up as its stuck. So how can I at least be able to pull the window up. I'll be using it for drifting so I'll mostly have it down anyway but I need to be able to pull it up so it doesn't get soaked with water on the inside. If I remove the regulator will the window just fall or will I be able to manually raise and lower it? What should I do? Thanks
Liam pink is offline   Reply With Quote
s14
