Old 03-14-2002, 12:46 AM   #1
ijon03
ijon03 is an unknown quantity at this point
I like to know if we lower the car when do we need camber kit?
Cause I heard if only 1.5 drop we dont need it unless the drop is bigger than that.
Will Eibach pro kit drop 1.5 and what brand of shock or straut shuold i use (my car is 97 model s14)
Thanks guy for the help.... &nbsp; &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/inlove.gif" border="0" valign="absmiddle" alt=''>
ijon03 is offline   Reply With Quote
Old 03-14-2002, 01:21 AM   #2
Ni5mo180SX
Ni5mo180SX is an unknown quantity at this point
Send a message via AIM to Ni5mo180SX
Yea might as well do it when you lower it and save yourself a lot of trouble down the line.
Mazda RX-7 FC3S: Jspec motor, ported turbo & wastegate, JIC FLT-A2 coilovers, Mazdatrix adj. rear camber link, TB mod, Koyo 53mm Radiator, Corksport Cat back/midpipe/downipe, 3" Al TID, Apex'i air cleaner, Mazda Comp. mission/motor/differential mounts, Mazdaspeed Strut Bar(R), FD torsen differential, HKS SSQV, HKS elec. boost gauge & elec water temp, Cusco Oil catch, 680cc secondary's, Walbro 255, Banzai Racing FCD, RB DTSS Eliminator bushings, Exedy Clutch & PP, Exedy chrome moly flywheel, RB oil baffle, RB dual alt. pulley, 5 lug conversion, FC3S.org thermal bypass pellet, KVR Cross drilled rotors, complete Energy PU bushings, stainless steel brake lines/clutch line, Aerodyne shroud panel, Azenis RS, and some other stuff. A hybrid of sorts I guess
Ni5mo180SX is offline   Reply With Quote
Old 03-14-2002, 01:25 AM   #3
tnord
tnord's Avatar
tnord is an unknown quantity at this point
i have prokits with no camber plates or anything, got the car alligned, and everything is within factory tolerances. it is true though that if you go with too big of a drop you will have to buy some extra hardware to "fix the problem."
tnord is offline   Reply With Quote
Old 03-14-2002, 01:34 AM   #4
ijon03
So tnardo what kind of shock do you use?
And if i go with prokiti dont need camber kit right?
Thanks <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Old 03-14-2002, 12:24 PM   #5
240racr
240racr is an unknown quantity at this point
Send a message via Yahoo to 240racr
I have a '97 with sportline springs. I got an alignment twice (I stood there and watched the second time), The rear will be fine, but the front will need a camber kit! There is no stock camber adjustment for the front of the s14's. I have had my springs for 3 months and the tire wear is horrible.
Also, you will need to do an alignment a few months later since the springs will settle and the camber will go bad.
Precision T3/T4, 65lb injectors, z32 brakes, AEM EMS, 360WHP
240racr is offline   Reply With Quote
Old 03-14-2002, 01:20 PM   #6
gmgs14
gmgs14 is an unknown quantity at this point
I had ground control coilovers on my old civic and didn't get a camber kit or anything. &nbsp;About a year later one of my Yoko Paradas blew out while I was driving. &nbsp;The tires were down to the steel belts on the inner side of both the front wheels. &nbsp;(Luckily only one blew) &nbsp;So when I go to lower my 240 I'm going to be real careful, tires are too expensive to be blowing out every year. &nbsp;BTW, it was lowered about 1.5 all around.
gmgs14 is offline   Reply With Quote
Old 03-14-2002, 02:14 PM   #7
thewholefnshow
thewholefnshow is an unknown quantity at this point
Send a message via ICQ to thewholefnshow
A lot of cars it is obvious when the camber is off, I can see on my friend car it is off, and he knows it is, but he likes to corner so hard he actually manages to wear the tires close to flat... but you can see it when it is off enough to hurt your tires... How many differnt people make camber kits for an s14 though?
thewholefnshow is offline   Reply With Quote
Old 03-14-2002, 02:19 PM   #8
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
I know of Ingalls and pdmracing but thats it. &nbsp;Gonna get mine aligned on monday and then we will see if I need a kit. &nbsp;My local Nissan Dealer does aftermarket mods for our cars and they lower them all the time. &nbsp;They know the factory settings also and tell me that I won't need a kit but if I want one they will gladly get one for me. &nbsp;Usually the dealer wants to do unnecessary work so I assume that it really doesn't need one if they tell me not to!
burgy240 is offline   Reply With Quote
Old 03-19-2002, 08:20 PM   #9
burgy240
burgy240's Avatar
I did not need a camber kit. &nbsp;I have the specs and all four wheels are easily within factory settings. &nbsp;Only need the kit if the drop is more than an inch and a half. &nbsp;If it is more than you probably want the camber adjust kit, but other wise it CAN be fixed through factory adjustment. &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
Old 03-19-2002, 09:23 PM   #10
wa-fu
wa-fu is an unknown quantity at this point
I have Pro Kit Springs. &nbsp;I took it to a Nissan dealer to have it alligned after I installed them. &nbsp;One year later I had to have new tires. &nbsp;Maybe it is my fault for not having it alligned after they settled? &nbsp;So I bought new tires and had it alligned again. &nbsp;I watched the guy do it. &nbsp;Front was easily w/in specs but rear is just barely in. &nbsp;(Anyone know if tire size has anything to do with this because I have wider tires on the back?) &nbsp;So I bought the PDM bushings and hope to get them in soon and then realign. &nbsp;Get the shop to give you a printout of what your allignment is so you'll know for sure.
...got to find the reason why my money's all gone...
wa-fu is offline   Reply With Quote
