Old 11-25-2004, 03:26 PM   #1
My240sx
My240sx's Avatar
My240sx is making a name for him/her selfMy240sx is making a name for him/her self
Airbags Install Problem
ok well i have a 97 s14 and i was in an accident where both airbags came out. So i went to the junk yard and found airbags and dash of of a 95 or 96 s14. Now everything fits correctly but the sensor that is under the rear seat, is two different ones, the older 240 is bigger than the one that is on my 97 right now. I was wondering if you even need to replace that or what do i need to do. Thank You
My240sx is offline   Reply With Quote
Old 11-25-2004, 05:24 PM   #2
projectRDM
projectRDM's Avatar
You have to replace it. The Kouki models use a different module, go back and get the airbag harness from the car and use it, you'll need to cut/splice the end that plugs into the dash harness.
FORMERLY R240NA
Old 11-25-2004, 06:10 PM   #3
My240sx
My240sx's Avatar
if i got the kouki model would i need to do anything or just plug and play??
Old 11-25-2004, 07:04 PM   #4
projectRDM
projectRDM's Avatar
You have a Kouki, right? Then obviously yes.
FORMERLY R240NA
Old 11-25-2004, 09:23 PM   #5
My240sx
My240sx's Avatar
ok so just to make sure i am doing it right if i go back i will be getting the whole air bag wiring harness assembly so that i will be replacing the whole wiring or would i just be cutting the plugs off the old one and cut/splice them onto the wiring already in my car??? Thanks for the help this is just first time trying to do this so wanna do it right.
Old 11-26-2004, 04:34 AM   #6
projectRDM
projectRDM's Avatar
Christ mang, it's not that hard.
You either can use a Kouki module and plug it right in, OR a Zenki module, with the airbag harness, and rewire the dash plug.
FORMERLY R240NA
