Old 07-19-2020, 05:16 PM   #1
TheVinylKingz
TheVinylKingz's Avatar
TheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura aboutTheVinylKingz has a spectacular aura about
SR SR20DET (Idle Air Control Valve) FAST Cleaning
My schedule is sometimes very busy and I don't always have time to work on my car (S13 with SR20DET). I want to clean my IACV, but don't want to take off the manifold. Can I unbolt the IACV and turn it sideways in order to clean it with "throttle cleaner" or do I really need to take it off?
I'm asking because I want to plan accordingly and don't want to rush it. My weekly schedule is busy and weekends are usually for the fam.
S13 SR, S14 KA
TheVinylKingz is offline   Reply With Quote
Old 07-19-2020, 05:32 PM   #2
S14rebuild
Sure, or take off the tube running to it and spay some brake cleanner throttlw cleaner in that too, hook it nack up and start the car(will kinda be hard to.start for a few)...repeat a few times. Could help, might not.
Whats the issue? Shitty idle?
Old 07-19-2020, 05:36 PM   #3
TheVinylKingz
Just started happening, it dies when coming to a stop. I have to feather it and give it gas while on neutral. I adjusted the idle and it appeared to fix the problem, but once in a while it stalls (dies) when coming to a stop.
S13 SR, S14 KA
Old 07-19-2020, 06:20 PM   #4
S14rebuild
There is also n adjust screw on the idle air control valve aswell
Old 07-19-2020, 07:09 PM   #5
TheVinylKingz
So has anyone ever cleaned their IACV with out taking the Intake manifold Off?
S13 SR, S14 KA
Old 07-21-2020, 11:35 AM   #6
Silv1401
Silv1401's Avatar
Silv1401 is an unknown quantity at this point
Yeah, just take the pre-throttle body tube off and spray some TB cleaner in there. Probably would avoid brake cleaner because of its tendency to break down rubber.
Sent from my SM-G950U using Tapatalk
Silv1401 is offline   Reply With Quote
Old 07-21-2020, 05:46 PM   #7
Kingtal0n
Kingtal0n's Avatar
The iacv does so little on an sr20. In fact the power FC has some kind of bug that prevents it from even working properly and nobody ever seems to notice.
most of the idle air comes from the wax element thing where the water flows through it to warm it and bring down the idle.
And most of the "dying when coming to stop" problems are because of people not using recirculated bypass valves or proper MAF positioning and hoses
