Old 07-30-2020, 07:29 PM   #1
epik1
epik1 is an unknown quantity at this point
PMC Motorsports 2JZ/5SPD ZF/S13
Hey guys,
anyone else using this combo?
- 2JZGTE
- BMW ZF 5SPD E46 Trans w/ E46 Clutch Slave
- In S13
Having an issue where my clutch isn't fully disengaging.
I've tried bleeding it a few times to make sure.
Was suggested to try and E36 Clutch slave and the rod ended up coming out when trying to bleed it.
Was also suggested to try adding a washer behind the brass pivot pin and to try a 3/4" Wilwood Master Cylinder, which I have on order right now but just want to see if anyone else has it working or has had the same issue.
Thanks!
epik1 is offline   Reply With Quote
