Old 11-30-2004, 06:53 PM   #1
Mr. Badlose
Mr. Badlose is an unknown quantity at this point
Send a message via AIM to Mr. Badlose
Brake stuff
So it seems my front right 240sx caliper is leaking out all of my brake fluid.
So I've got three options now.
1) Rebuild the front stock calipers. (I have nice Carbotech XP-8s in there right now, and the rotors are in good condition)
2) Use the front Silvia (Altima) calipers I have laying around, buy Altima rotors and pads.
3) Use the front J30 (same as Q45 I think) calipers I have laying around, buy rotors, redrill myself, buy some pads.
What would YOU do? Thanks Zilvians.
Mr. Badlose is offline   Reply With Quote
Old 11-30-2004, 11:42 PM   #2
Mike Wazowski
Mike Wazowski has a little shameless behavior in the past
I would do this all over again.
http://www.my350z.com/gallery/view_p...album08&id=aaq
Mike Wazowski is offline   Reply With Quote
Old 12-01-2004, 09:52 AM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
I would probably go with the silvia calipers.
sykikchimp is offline   Reply With Quote
Old 12-01-2004, 10:00 AM   #4
Ritz S14
Ritz S14's Avatar
Depending where in CA you are, I have a set of stock s14 calipers in good condition for $31picked up. Hayward, CA.
Ritz S14 is offline   Reply With Quote
Old 12-01-2004, 11:43 AM   #5
old_s13
old_s13's Avatar
old_s13 is an unknown quantity at this point
i would spend my time and money on brakes that dont suck?
old_s13 is offline   Reply With Quote
Old 12-01-2004, 12:17 PM   #6
Mr. Badlose
Just what I need, a 4th set of front calipers, no thanks.
Old 12-01-2004, 04:42 PM   #7
old_s13
old_s13's Avatar
why have you gone through so many calipers? calipers are not that complex, especially single piston. you have:
- one piston
- one seal and one dust cover
- sliding pin
keep the fluid changed and make sure the caliper slides well (grease the pin) and you're done. why the complexity here? if you want better, go with NA 90 Z32 brakes.. they're small and good. If you want more, go with Z32 turbo brakes. If you want more than that, go with Brembo Z33 brakes. If you want more than that, get an anchor like the batmobile has, it will help you drift around turns too.
Mike
Old 12-01-2004, 09:03 PM   #8
Mr. Badlose
I haven't gone through that many, I've just kind of collected them.
I've had the Silvia ones for 2 years now from my front clip and I've never put them on, and some J30s I thought I may as well grab at the junkyard a week ago.
And I've never seen Adam West deploy an anchor from the Batmobile.
Edit: Was it Michael Keaton who had the tether that went around poles?
Old 12-02-2004, 09:42 AM   #9
thx247
thx247 is an unknown quantity at this point
touche....
For a stock powered car I think the stock calipers with the XP8's still leave something to be desired, the silvia fronts have a much nicer pedal feel to them, but the best I've used is the XP's, 26mm Z32's front and rear and bias valve. I find it much easier to brake at the limit using a sensitive pedal. The stock brakes with XP's vs the Z32s with XP's is like comparing a wet spounge and a rock together.
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
Old 12-02-2004, 10:51 AM   #10
old_s13
old_s13's Avatar
upgrade the master cylinder and use front AND rear Z brakes and you really feel a much better improvement.
front Z brakes arent enough. a bias valve sounds like it could cure the bias issue but it wont resolve the uneven pedal engagement.
Old 12-02-2004, 06:43 PM   #11
thx247
The Z brakes are the rock, the stockers are the sponge. Sorry if I wasn't clear.
