Old 03-02-2021, 09:57 PM   #1
shoottothrill
shoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really niceshoottothrill is just really nice
s14 Engine RPM falls switching into neutral
Hey guys, I've got a KA S14, stock ECU, stock engine, stock most things. It is a factory auto, manual swapped, still using the stock 3D auto ecu.
What I'm finding is that when I have the clutch in 1st gear, it'll idle where I would expect, 800-900 rpm. Without moving anything else (clutch still in), and switching into neutral, the idle will fall to 500-600 rpm.
If the idle fell the opposite way, neutral to 1st, that would make a fair bit more sense to me. Is this a byproduct of having the auto ecu still in? Would swapping in a 3c manual ecu fix the issue? Anybody ever run into this issue?
Thanks for the info!
shoottothrill is offline   Reply With Quote
engine idle, idle, ka24de, manual swap, s14
