Old 06-22-2022, 10:12 PM   #1
Quiche2192
Quiche2192 is an unknown quantity at this point
S13 SR20DET CAS issue
I'm having trouble idling and accelerating. Idling is very inconsistent and the engine will eventually stop if I don't rev it up. Revving it up sounds really bad. Breaks up badly. Once up there, it'll run ok, but getting up there sounds bad.
Running stock ECU. I checked the diagnostic LED and got code 11, which is the CAS code. Checked CAS wiring. 12V feed is good. Ground is good. 180 Deg signal to ECU is good. 1 Deg signal to ECU is good.
Thought it was the CAS itself so I pulled the CAS and found that both the 180 Deg and the 1 Deg signals were sending square waves with voltages ranging from 0.3 to 5.2 volts, which seems good.
Timing was set correctly.
So I am at a loss as far as what might be going on. I think it's unlikely, but I suspect:
- Grounding issue
- Bad MAF and ECU is just getting confused and throwing the 11 code
- Bad O2 sensor and ECU is also getting confused
Appreciate any input
Quiche2192 is offline   Reply With Quote
Old 06-23-2022, 05:34 AM   #2
jr_ss
I’d find a local with a known good MAF and try that. Sure you have fuel/ignition on all cylinders?
Old 06-23-2022, 09:11 PM   #3
Quiche2192
Looked into it today and found that... my alternator was unplugged. I haven't been able to start the car yet though cause I gotta put the CAS back in, but haven't had the time.
Old 06-23-2022, 09:42 PM   #4
Kingtal0n
Kingtal0n's Avatar
boost leak test, pressure test, OEM maf plumbing, rule out the maf
Rev the engine without maf connected -> Revs fine = problem is maf (only revs to 2500 or something but its clean)
