![]() Join Date: Oct 2004
Window Regulator Pulley Fix
Hey All,
So S13's window regulator pulleys are all nylon plastic, which kid of sux. As you can see its broken in the upper left hand corner. Usually there is a pulley with a pin through it. ![]() ![]() To Fix - Dremel through the back side of the rivet and pull out the entire pulley Its roughly a 1/4" hole. ![]() Get Part Number 9466T54 - Pulley for Wire Rope Ball Bearing, 3/64" Rope Diameter, 35 lb., 1/4" Shaft Diameter, Nylon 1 - 1/4" round bolt with machined head because you need to be low profile 1 - 1/4" jam nut case you also need low profile 2 - 1/4" round lock washer. (you don't need the washer in the picture....) ![]() Bolt through the cable side of the pulley, then behind the pull and the regulator plate, put a lock washer to offset it, then on the other side put lock washer and jam nut with locktite ![]() ![]()
![]() Join Date: Jun 2003
Trader Rating: (130)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 130 reviews
Plus rep for you sir!!!
Thanks man.... the motor and track was good, so I thought it'd be a waste of money to through out something could cost me 15 bux to fix.....
